Help with using a 433mhz tx and attiny85
Hello
I am trying to use a attiny85 to transmit an one byte int to a arduino Uno r3 using a simple 433mhz transmitter and receiver. I have no idea how to do this. I tried to use the virtualwire library but I couldn't get my arduino didn't receive a response when I used the example code. I know there is a new library called radiohead but I haven't used that. I am new to arduino so please keep it simple.
Thanks
Xeno
how do you connected RF transmitter and receiver to attiny85 and uno respectively.?
Take a look at the Manchester library
http://mchr3k.github.io/arduino-libs-manchester/
Erni:
Home - Arduino Manchester Encoding - Mchr3k
Thank you so much!
The Virtualwire library works a treat as well.
I have hooked up a couple of sensors and used watchdog without a problem:
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@airspayce.com)
// Copyright (C) 2008 Mike McCauley
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
// 0=16ms, 1=32ms,2=64ms,3=128ms,4=250ms,5=500ms
// 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
volatile boolean f_wdt = 1;
  setup_watchdog(9); // approximately 4 seconds sleep
    //Serial.begin(9600);	  // Debugging only
    //Serial.println("setup");
    // Initialise the IO and ISR
    //vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(500);	 // Bits per sec
    vw_set_tx_pin(0);    //Transmitter on pin 4 of the ATtiny85
 char TSL257_IN=A2;
 int PWR=3;
 pinMode(TSL257_IN,INPUT);
 pinMode(PWR, OUTPUT);
     if (f_wdt==1) {  // wait for timed out watchdog / flag is set when a watchdog timeout occurs
    f_wdt=0;       // reset flag
    union {
  uint8_t bytes[2];
  int value;
} data;
    digitalWrite(PWR,HIGH);
    data.value=analogRead(TSL257_IN);
    digitalWrite(PWR,LOW);
    data.value=data.value+2000;
    vw_send(data.bytes, sizeof(data)); // send the char (msg)
    vw_wait_tx(); // Wait until the whole message is gone
    system_sleep();
     }// if f_wdt check
} // voiud loop
void system_sleep() {
  cbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter OFF
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
  sleep_enable();
  sleep_mode();                        // System sleeps here
  sleep_disable();                     // System continues execution here when watchdog timed out
  sbi(ADCSRA,ADEN);                    // switch Analog to Digitalconverter ON
void setup_watchdog(int ii) {
  byte bb;
  int ww;
  if (ii > 9 ) ii=9;
  bb=ii & 7;
  if (ii > 7) bb|= (1<<5);
  bb|= (1<<WDCE);
  ww=bb;
  MCUSR &= ~(1<<WDRF);
  // start timed sequence
  WDTCR |= (1<<WDCE) | (1<<WDE);
  // set new watchdog timeout value
  WDTCR = bb;
  WDTCR |= _BV(WDIE);
// Watchdog Interrupt Service / is executed when watchdog timed out
ISR(WDT_vect) {
  f_wdt=1;  // set global flag
