Help with using capacitive touch sensor to turn on and off led strip
I'm new to coding with arduino and I tried combining two different projects to allow a capacitive touch sensor to turn on and off an Led strip. Here is the code:
#include <CapacitiveSensor.h>
CapacitiveSensor   cs_4_8 = CapacitiveSensor(4,8); // 1M resistor between pins 4 & 8, pin 8 is sensor pin, add a wire and or foil
   cs_4_8.set_CS_AutocaL_Millis(0xFFFFFFFF);// turn off autocalibrate on channel 1 - just as an example
   pinMode(7,OUTPUT);
   pinMode(5, OUTPUT);
 int i;
 long sensor1 =  cs_4_8.capacitiveSensor(50);
    Serial.println(sensor1);  // print sensor output
   if(sensor1 >= 400)
    (i = 0; i < 255; i++) {
    analogWrite(PIN, i);
    delay(FADESPEED);
   else{
    (i = 255; i > 0; i--) {
    delay(FADESPEED);
I get this when I try to verify:
sketch_apr10a:19:30: error: expected ')' before ';' token
    if(sensor1 >= 400); (i = 0; i < 255; i++)
sketch_apr10a:19:44: error: expected ';' before ')' token
sketch_apr10a:24:4: error: 'else' without a previous 'if'
sketch_apr10a:26:13: error: expected ')' before ';' token
sketch_apr10a:26:25: error: expected ';' before ')' token
sketch_apr10a:31:1: error: expected '}' at end of input
exit status 1
Maybe you wanted:
for (int i = 0; i < 255; i++) :wink:
If statements rarely end with semicolons.
Do NOT put two statements on one line.
