Hi
Could someone help me out on this one?
When I send "http://xxx.xxx.xxx.xxx/aklsjdhwuwqeoiuys/openport2" or "http://xxx.xxx.xxx.xxx/aklsjdhwuwqeoiuys/openport1" through the browser the wemos is freezing after 5-10 sec, what am i doing wrong?
The power supply im using i 5V 1500ma with an 10v 1000uf capacitor.
#include <ESP8266WiFi.h>
// defines pins numbers
const char* ssid = "This is my Wi-Fi!";
const char* password = "1123456789";
int port1 = D5;
int port2 = D6;
WiFiServer server(80);
 delay(10);
 pinMode(port1, OUTPUT);
 pinMode(port2, OUTPUT);
 digitalWrite(port1, HIGH);
 digitalWrite(port2, HIGH);
 // Connect to WiFi network
 Serial.print("Connecting to ");
 Serial.println(ssid);
 WiFi.begin(ssid, password);
  Serial.print(".");
 Serial.println("");
 Serial.println("WiFi connected");
 // Start the server
 server.begin();
 Serial.println("Server started");
 // Print the IP address
 Serial.print("Use this URL : ");
 Serial.print("http://");
 Serial.print(WiFi.localIP());
 Serial.println("/");
 // Check if a client has connected
 WiFiClient client = server.available();
 if (!client) {
  return;
 // Wait until the client sends some data
 Serial.println("new client");
 while(!client.available()){
  delay(1);
 // Read the first line of the request
 String request = client.readStringUntil('\r');
 Serial.println(request);
 client.flush();
 // Match the request
 if (request.indexOf("/aklsjdhwuwqeoiuys/openport1") != -1) {
  digitalWrite(port1, LOW);
 else if (request.indexOf("/aklsjdhwuwqeoiuys/openport2") != -1){
  digitalWrite(port2, LOW);
 // Return the response
 client.println("Content-Type: text/html");
 client.println(""); // do not forget this one
 client.println("<!DOCTYPE HTML>");
 client.println("<html>");
 client.println("
 client.println("<meta http-equiv=\"refresh\" content=\"0;url=http://zjonesz.net:8000/asdasdjhgqwertyuqwe/\">");
 client.println("</html>");
 delay(1);
 Serial.println("Client disconnected");
 Serial.println("");
