Hex Color Value to RGB array help
hey all
i have search long and hard for a quick solution to a hex to array convertor,
strol() just hasen’t provided the intended result, or maybe i am doing it wrong.
what i need is an array representation of a converted hex number:
pseudo
hexToArray(hex)
return array;
array = hexToArray(“FFFFFF”); // this should yeild (255,255,255);
strtol is a good way of converting the string to an efficient packed 24 bit container for the RGB values that you need. You could then add some convenience #defines to get at the components of the value returned by strtol:
define RED(a) (a>>16)
define GREEN(a) ((a>>8) & 0xff)
define BLUE(a) (a & 0xff)
Don't forget that the 'base' parameter to strtol is 16.
