Hex To Ascii String
Hi All,
Before any of you stated that this is a duplicate topics, please read on because I can assure you it is not.
I had search numerous time for the solution and I still couldnt find any in the forum. So, please bear with me and read on.
Situation :
  1. I got a reply from serial device with the following data (hex) :
    30
    44
    42
    45
  2. I store all of the data into an array. Lets call it arrayA.
arrayA[0] 0x30
arrayA[1] 0x44
arrayA[2] 0x42
arrayA[3] 0x45
  1. So, I need to convert that to ascii :
0x30 0x44 0x42 0x45
0 D B E
I use this function :
int DecToHexStr (int Nilai)
             if ((Nilai >=48) && (Nilai <=57)) //0-9
                   int HexNilai;
                   HexNilai = Nilai - '0';
                   return HexNilai;
             else if ((Nilai >=65) && (Nilai <=70))
                   char HexNilaiB;
                   if (Nilai == 65) HexNilaiB = 65;
                   if (Nilai == 66) HexNilaiB = 66;
                   if (Nilai == 67) HexNilaiB = 67;
                   if (Nilai == 68) HexNilaiB = 68;
                   if (Nilai == 69) HexNilaiB = 69;
                   if (Nilai == 70) HexNilaiB = 70;
                   return HexNilaiB;
  1. So, we will get :
    0DBE
But, "DBE" is still not stored as character.
5. How can I combined all of the "0","D","B","E" to become one hex number = 0x0DBE
6. And Convert it to decimal so that I can send the value trough serial port?
Have you seen this.
http://www.theskyway.net/en/converting-hex-as-a-string-to-actual-hex-values/
LarryD:
Have you seen this.
Thanks for the link and quick reply!. I will be looking into it.
