So what I want to create a robo car with a chassis kit which can be controlled with an app and voice and also with a glove like gesture control
I also want the robot to avoid obstacles and do the line following and also it should have a robot arm to pick things up and the robotic arm should be controlled with the app can anyone help me do this and I have most of the arduino things and if i need to buy more I can
Hello,
I don't have the knowledge to answer fully to you question. But i think you could use this build by howtomechatronics.com, as a base for your build.
https://howtomechatronics.com/projects/arduino-robot-arm-and-mecanum-wheels-platform-automatic-operation/
I looked at his video, and the article and i find that he explaines very well. So I hope this link can help.
You should contact this guy - it sounds like you have very similar projects
thanks I will try to contact him
It is very unlikely to bring you much fun, if you start hard projects as a beginner.
I would suggest mastering the Arduino environment step by step,
and using small steps, start with LEDs, buttons, a servo, a motor, a stepper, and photo sensors.
App, voice control, and gesture control probably need some very capable Arduinos.
Powering a motorized robot arm is another problem to be solved.
Topic closed due to the duplicate account used by the OP
