Hi guys .. I receive this error message. Can you help me?
hi guys ..
In file included from C:\Users\ahmed\Downloads\gpsObstaclePID1.00\gpsObstaclePID1.00.ino:12:0:
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:45:21: error: two or more data types in declaration of 'parameter'
                     double, int);
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:45:27: error: expected ')' before ',' token
                     double, int);
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:45:29: error: expected unqualified-id before 'int'
                     double, int);
C:\Users\ahmed\Downloads\gpsObstaclePID1.00\gpsObstaclePID1.00.ino:73:69: error: no matching function for call to 'PID::PID(double*, double*, double*, double&, double&, double&, int)'
 PID steeringPID(&currHeading, &Kgas, &currBearing,Kp, Ki, Kd, DIRECT);
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:24:5: note: candidate: PID::PID(double*, double*, double*, double*, double, double, double, double, int)
     PID(double*, double*, double*, double*,       // * constructor.  links the PID to the Input, Output, and
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:24:5: note:   candidate expects 9 arguments, 7 provided
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:20:5: note: candidate: PID::PID(double*, double*, double*, double*, double, double, double, double, int, int)
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:20:5: note:   candidate expects 10 arguments, 7 provided
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:5:7: note: candidate: constexpr PID::PID(const PID&)
 class PID
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:5:7: note:   candidate expects 1 argument, 7 provided
C:\Users\ahmed\Documents\Arduino\libraries\PID/PID_v1.h:5:7: note: candidate: constexpr PID::PID(PID&&)
exit status 1
Compilation error: no matching function for call to 'PID::PID(double*, double*, double*, double&, double&, double&, int
Welcome to the forum
Please post your full sketch, using code tags when you do
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
Thank you
This code was copied from forum and I am trying to develop it for my project
#include <Wire.h>
#include <PID_v1.h>
#include <quaternionFilters.h>
#include <MPU9250.h>
#include <TinyGPS++.h>
#include <math.h>
#include <Servo.h>
#include <Maxbotix.h>
const int pinLD = 12;    // Digital output to left motor for direction
const int pinLA = 11;    // Analog output to left motor for speed control
const int pinRD = 13;    // Digital output to right motor for direction
const int pinRA = 3;     // Analog output to right motor for speed control
const int gasAvg = 155;  // Average analog output to both motors... FLOOR IT BABY!!!
const int servoPin = 9;
const int pwSonarPin = 5;  // The digital pin for MaxSonar in PW mode
const float coastClear = 70.0;    // Threshold distance to begin avoidance
const float frontMinDist = 20.0;  // Threshold distance to take "evasive action"
const int servoDelay = 150;  // Time for servo to swing ~180 deg
const int sonarDelay = 250;  // Time to scan
const int headA1 = 0;        // Servo position looking  85 deg right
const int headA2 = 15;       // Servo position looking 60 deg right
const int headA3 = 35;       // Servo position looking 30 deg right
const int headCenter = 65;
const int headA4 = 95;    // Servo position looking -30 deg (left)
const int headA5 = 125;   // Servo position looking -60 deg
const int headA6 = 150;   // Servo position looking ~90 deg left
const float alpha1 = 85;  // Angle that's 90 degrees to right
const float alpha2 = 60;
const float alpha3 = 30;
const float alphaTol = 20;
const float tol = 10;  // 10 degree angle tolerance for turning
const double Kp = 6;
const double Ki = 0.2;
const double Kd = 1;  // PID control constants
const int magBias[] = { 125, 45, -50 };
const double R = 6371008.8;
const double range = 10;  // Within 7 meters call it good
double currHeading, Kgas;  // PID Setpoint, input and output vars
const double waypoint[] = { 29.540158, -95.110300 };
double coord[2];
double currDist;
double currBearing;
int dist[6];
unsigned long prevMillis = 0;
unsigned long currMillis = 0;
byte counter = 0;  // For lookAround
bool looking = false;
bool isObstacle = false;
bool finishedLooking = false;  // For the distance measurement
bool newResults = false;       // For the distance measurement
bool imReady = false;          // for the distance measurement
MPU9250 myIMU;
PID st(double *currHeading, double *Kgas, double *currBearing, double Kp, double Ki, double Kd, int DIRECT);
TinyGPSPlus gps;
Maxbotix sonar(5, Maxbotix::PW, Maxbotix::LV, Maxbotix::BEST);
Servo head;
  Wire.begin();
  pinMode(pinLD, OUTPUT);
  pinMode(pinRD, OUTPUT);
  Serial.begin(9600);  // GPS attached to Serial1 runs at 9600 baud
  head.attach(servoPin);
  head.write(headCenter);
  myIMU.MPU9250SelfTest(myIMU.selfTest);
  myIMU.calibrateMPU9250(myIMU.gyroBias, myIMU.accelBias);
  myIMU.initMPU9250();
  myIMU.initAK8963(myIMU.factoryMagCalibration);
  myIMU.getAres();
  myIMU.getGres();
  myIMU.getMres();
  getIMUdata();
  calcYawPitchRoll();
  getGPSinfo();
  currHeading = -myIMU.yaw;
  st.SetOutputLimits(-100, 100);
  st.SetMode(AUTOMATIC);
  getGPSinfo();              // gets coordinates, calcs currDist and currBearing
  getIMUdata();              // gets accel, gyro and magnetometer data
  calcYawPitchRoll();        // calcs yaw, pitch and roll
  currHeading = -myIMU.yaw;  // compass heading is negative of yaw
  if (!isObstacle) { checkForObstacles(); }
  if (isObstacle) { avoidObstacles(); }
  if ((currDist > range) && (!looking)) {
    st.Compute();
    pidDrive(Kgas);
    stopCar();
}  // end loop()
void checkForObstacles() {
  float frontDist = 0;
  frontDist = sonar.getRange();  // Head pointing forward, measures distance in cm
  if (frontDist < coastClear) {
    isObstacle = true;
    isObstacle = false;
void avoidObstacles() {
  stopCar();
  if (!looking && !imReady) {
    imReady = true;  // I'M READY!  I'M READY!  I'M READY!
  if (imReady) {
    counter = 1;              // Keeps track of place in switch/case statement
    prevMillis = currMillis;  // Going to use this to time my servos
    imReady = false;
    looking = true;
    finishedLooking = false;  // Yes, this may be extraneous
  if (!finishedLooking) { lookAround(); }
  if (finishedLooking && newResults) {
    turnTowardsFreedom();
// Turn head six different angles and take distance at each
void lookAround() {
  currMillis = millis();
  switch (counter) {
    case 1:
      head.write(headA1);
      if ((currMillis - prevMillis) > servoDelay) {
        counter = 2;
        prevMillis = millis();
    case 2:
      dist[0] = round(sonar.getRange());
      if ((currMillis - prevMillis) > sonarDelay) {
        counter = 3;
    case 3:
      head.write(headA2);
        counter = 4;
    case 4:
      dist[1] = round(sonar.getRange());
        counter = 5;
    case 5:
      head.write(headA3);
        counter = 6;
    case 6:
      dist[2] = round(sonar.getRange());
        counter = 7;
    case 7:
      head.write(headA4);
        counter = 8;
    case 8:
      dist[3] = round(sonar.getRange());
        counter = 9;
    case 9:
      head.write(headA5);
        counter = 10;
    case 10:
      dist[4] = round(sonar.getRange());
        counter = 11;
    case 11:
      head.write(headA6);
        counter = 12;
    case 12:
      dist[5] = round(sonar.getRange());
        counter = 13;
    case 13:
      if ((currMillis - prevMillis) > (3 * servoDelay)) {
        counter = 14;
    case 14:
      counter = 0;
      finishedLooking = true;
      looking = false;
      newResults = true;
void turnTowardsFreedom() {
  float turnAngle = bubbleAngle();
  getIMUdata();
  calcYawPitchRoll();
  currBearing = currHeading + turnAngle;
  if (currBearing > 180) { currBearing = currBearing - 360; }
  if (currBearing < -180) { currBearing = currBearing + 360; }
  if (turnAngle > tol) {
    while (turnAngle > tol) {
      turnRight();
      getIMUdata();
      calcYawPitchRoll();
      turnAngle = currBearing - currHeading;
      if (turnAngle > 180) { turnAngle = turnAngle - 360; }
      if (turnAngle < -180) { turnAngle = turnAngle + 360; }
    stopCar();
  if (turnAngle < -tol) {
    while (turnAngle < -tol) {
      turnLeft();
      getIMUdata();
      calcYawPitchRoll();
    stopCar();
  newResults = false;
  isObstacle = false;
// Bubble Rebound Algorithm turn angle calculator
// I. Susnea, V. Minzu, G. Vasiliu, "Simple, real-time obstacle
//  avoidance algorithm for mobile robots," Recent Advances in
//  Computational Intelligence, Man-machine Systems and Cybernetics,
//  WSEAS Press, 2009, pp 24-29, ISBN: 978-960-474-144-1
float bubbleAngle() {
  float sumDist = 0;
  float alphaR = 0;
  float alphaAdj = 0;
  for (int i = 0; i < 6; i++) {
    sumDist = sumDist + dist[i];
  alphaR = (alpha1 * (dist[0] - dist[5])
            + alpha2 * (dist[1] - dist[4])
            + alpha3 * (dist[2] - dist[3]))
           / sumDist;
  if (abs(alphaR) < alphaTol) {
    if (alphaR <= 0)
      alphaAdj = -45;
    else if (alphaR > 0)
      alphaAdj = 45;
  } else
    alphaAdj = alphaR;
  return alphaAdj;
void pidDrive(double gasDiff) {
  int rightGas = round(gasAvg - gasDiff);
  int leftGas = round(gasAvg + gasDiff);
  digitalWrite(pinLD, LOW);
  digitalWrite(pinRD, LOW);
  analogWrite(pinLA, leftGas);
  analogWrite(pinRA, rightGas);
}  // end pidDrive(...)
void stopCar() {
  digitalWrite(pinLD, HIGH);
  digitalWrite(pinRD, HIGH);
  analogWrite(pinLA, 0);
  analogWrite(pinRA, 0);
void turnRight() {
  digitalWrite(pinLA, gasAvg);
  digitalWrite(pinRA, gasAvg);
void turnLeft() {
void getIMUdata() {
  myIMU.readAccelData(myIMU.accelCount);
  myIMU.ax = (float)myIMU.accelCount[0] * myIMU.aRes;
  myIMU.ay = (float)myIMU.accelCount[1] * myIMU.aRes;
  myIMU.az = (float)myIMU.accelCount[2] * myIMU.aRes;
  myIMU.readGyroData(myIMU.gyroCount);
  myIMU.gx = (float)myIMU.gyroCount[0] * myIMU.gRes;
  myIMU.gy = (float)myIMU.gyroCount[1] * myIMU.gRes;
  myIMU.gz = (float)myIMU.gyroCount[2] * myIMU.gRes;
  myIMU.readMagData(myIMU.magCount);
  myIMU.mx = (float)myIMU.magCount[0] * myIMU.mRes
               * myIMU.factoryMagCalibration[0]
             - magBias[0];
  myIMU.my = (float)myIMU.magCount[1] * myIMU.mRes
               * myIMU.factoryMagCalibration[1]
             - magBias[1];
  myIMU.mz = (float)myIMU.magCount[2] * myIMU.mRes
               * myIMU.factoryMagCalibration[2]
             - magBias[2];
  // Must be called before updating quaternions!
  myIMU.updateTime();
  // This is for (x, y, z) axes of magnetometer aligned with (y, x, -z) axes
  // of gyro/accelerometer.
  MahonyQuaternionUpdate(myIMU.ax, myIMU.ay, myIMU.az, myIMU.gx * DEG_TO_RAD,
                         myIMU.gy * DEG_TO_RAD, myIMU.gz * DEG_TO_RAD, myIMU.my,
                         myIMU.mx, myIMU.mz, myIMU.deltat);
void calcYawPitchRoll() {
  myIMU.yaw = atan2(2 * (*(getQ() + 1) * *(getQ() + 2) + *getQ() * *(getQ() + 3)), *getQ() * *getQ() + *(getQ() + 1) * *(getQ() + 1) - *(getQ() + 2) * *(getQ() + 2) - *(getQ() + 3) * *(getQ() + 3));
  myIMU.pitch = -asin(2 * (*(getQ() + 1) * *(getQ() + 3) - *getQ() * *(getQ() + 2)));
  myIMU.roll = atan2(2 * (*getQ() * *(getQ() + 1) + *(getQ() + 2) * *(getQ() + 3)), *getQ() * *getQ() - *(getQ() + 1) * *(getQ() + 1) - *(getQ() + 2) * *(getQ() + 2) + *(getQ() + 3) * *(getQ() + 3));
  myIMU.pitch *= RAD_TO_DEG;
  myIMU.yaw *= RAD_TO_DEG;
  //  myIMU.yaw -= 2.4;   //Declination of Webster, TX - not needed due to offset mount
  myIMU.roll *= RAD_TO_DEG;
void getGPSinfo() {
  while (Serial.available() > 0)
    if (gps.encode(Serial.read())) {
      coord[0] = gps.location.lat();
      coord[1] = gps.location.lng();
      currDist = distance(coord, waypoint);
      currBearing = bearing(coord, waypoint);
double distance(double *Coord, double *Waypt) {
  double rCoord[2];
  double rWaypt[2];
  rCoord[0] = Coord[0] * PI / 180;
  rCoord[1] = Coord[1] * PI / 180;
  rWaypt[0] = Waypt[0] * PI / 180;
  rWaypt[1] = Waypt[1] * PI / 180;
  double sin2Lats = sin((rWaypt[0] - rCoord[0]) / 2) * sin((rWaypt[0] - rCoord[0]) / 2);
  double sin2Lngs = sin((rWaypt[1] - rCoord[1]) / 2) * sin((rWaypt[1] - rCoord[1]) / 2);
  double cosLat1 = cos(rCoord[0]);
  double cosLat2 = cos(rWaypt[0]);
  double sqRt = sqrt(sin2Lats + cosLat1 * cosLat2 * sin2Lngs);
  double d = 2 * R * asin(sqRt);
  return d;
double bearing(double *Coord, double *Waypt) {
  double rCoord[2];
  double rWaypt[2];
  double sinLngs = sin(rWaypt[1] - rCoord[1]);
  double cosLngs = cos(rWaypt[1] - rCoord[1]);
  double sinLat2 = sin(rWaypt[0]);
  double sinLat1 = sin(rCoord[0]);
  double term1 = sinLngs * cosLat2;
  double term2 = cosLat1 * sinLat2 - sinLat1 * cosLat2 * cosLngs;
  double b = atan2(term1, term2) * 180 / PI;
  return b;
In this file: Arduino-PID-Library/PID_v1.h at master · br3ttb/Arduino-PID-Library · GitHub
Here are lines 44 and 45 in PID.h:
    void SetTunings(double, double,       // * overload for specifying proportional mode
                    double, int);
Maybe the "slash-space-asterisk" is interpreted as "slash-asterisk" (a comment)... remove the "*"?
thank you
Was this a solution?
