I used parseInt() function to get integer value from Serial port buffer.
But this function can get only positive integer value not negative value. So I made new function parseInt2() and those code is below.
int parseInt2(){
int i=0;
int data=NULL;
int predata =NULL;
int minusSwitch = 0;
int memory[10]={};
int order=0;
int array_length=0;
while(Serial.available()){
predata = Serial.read();
if(predata == 45){
minusSwitch=1;}
}* else break; } for(int j=0;j<array_length;j++){ data = (data*10)+memory[j];} if(minusSwitch==1){ data=data*(-1); } minusSwitch=0; return data; } and I used this parseInt2() with arduino Mega 2560 like below . void setup(){
Serial.begin(9600);* } void loop(){
int number=NULL;*
if(Serial.available()){*
number = parseInt2();*
Serial.println(number);*
Serial.println(-1)*
delay(1000);*
else{*
Serial.println("There's no data to print");*
delay(1000);}*
*} * when I write positive integer value on Serial monitor, it works correctly. But when I write negative integer value, Serial monitor shows '0' and 'Absolute integer value' like ------------------------------------------------ There's no data to print There's no data to print <---------------------I write -10 on Serial monitor and send 0 10 There's no data to print . . . . . Please let me know why like this. Is there any function in Arduino library to get both positive and negative integer value from Serial buffer???? Thanks
BZZZZZT!
Have a close look at parseInt.
Here's its source
long Stream::parseInt(char skipChar)
boolean isNegative = false;
long value = 0;
int c;
c = peekNextDigit();
// ignore non numeric leading characters
if(c < 0)
return 0; // zero returned if timeout
do{
if(c == skipChar)
; // ignore this charactor
else if(c == '-')
isNegative = true;
else if(c >= '0' && c <= '9') // is c a digit?
value = value * 10 + c - '0';
read(); // consume the character we got with peek
c = timedPeek();
while( (c >= '0' && c <= '9') || c == skipChar );
if(isNegative)
value = -value;
return value;
But, the real question is why are you trying to re-implement the parseInt() function in the Stream class that HardwareSerial derives from? It already knows how to deal with negative numbers.
Thanks a lot Can you let me know how to get negative numbers from Serial.buffer?? Actually, I am trying to send String of numbers (such as 100:200:300:400:......) to Serial port and Arduino read this numbers.
