After listing the SD contents on an lcd/Serial. I am facing the problem where it is displaying hidden files beginning with '.' (specifically .Trashes)
By default when I try and open a folder to select another folder/file it always seems to jump to .Trashes (last printed).
I have attempted to restrict the SD card from allowing these types of files onto the SD card in the first place. However, this didn't seem to work.
Is there a simple implementation when listing the files to say: "Do not print files beginning with ".". And will the problem occur when trying to select a file, although it is not being displayed, still exists within the SD card and therefore could be selected.
So far I can only think of saying within the printing function if(SD.exists("."){}
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
#include <string>
#include <Bounce2.h>
//#include <Wire.h>
#include <Encoder.h>
#include "play_sd_wav.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "displayFunctions.h"
Adafruit_SSD1306 display(128, 64, &Wire, -1);
#define MOSI_PIN 11
#define SCK_PIN 13
#define CS_PIN = BUILTIN_SDCARD
#define maxNumCharDisplay 50
define:
- A char array to store the WHOLE file path
- a char array to store a FILE
- a char array to store a FOLDER
procedure:
- Concatenate what the select button deems to be a File or Folder
- if it is a Folder, use the the list directory function to pass whatever folder has been selected.
- it is a file,
- for both file or folder, use the SD.open(..concatenation of either folder or file with the root directory).
Bounce returnButton = Bounce(35, 10);
Bounce selectButton = Bounce(36, 10);
Bounce scrollButton = Bounce(37, 10);
const int encoderPin1 = 5; // Encoder pin 1
const int encoderPin2 = 6; // Encoder pin 2
Encoder myEncoder(encoderPin1, encoderPin2); // Initialize encoder
int fileCount = 0;
File currentDirectory;
char rootSampleDirectory[30];
char folderNameBuff[80];
char fileNameBuff[80];
char storedPath[80];
String presetStr[40];
char* folderList[20];
int folderCounter = 0;
int x = 0; // no. of files within the main directory?
char* folder;
int numTabs;
AudioPlaySdWav playWav;
displayInit();
display.setCursor(0, 0);
display.setTextColor(SSD1306_BLACK,SSD1306_WHITE); // Draw white text
display.println("SD CARD: ");
pinMode(35, INPUT_PULLUP);
pinMode(36, INPUT_PULLUP);
pinMode(37, INPUT_PULLUP);
SPI.setMOSI(MOSI_PIN);
SPI.setSCK(SCK_PIN);
if (!(SD.begin(BUILTIN_SDCARD))) {
//while (1) {
Serial.println("unable to access SD card.");
//sprintf(rootSampleDirectory, "/SdCardAudio/"); // This won't work becuase when the loop comes back round it will always open at the root folder, not the selected folder/directory
currentDirectory = SD.open("/");
printDirectory(currentDirectory, 0);
//display.display();
void printDirectory(File dir, int numTabs) {
//int index = 0;
while (true) {
File entry = dir.openNextFile();
if (! entry)
// no more files
for (uint8_t i = 0; i < numTabs; i++)
//Serial.println('\t');
//display.println('\n');
//index = numTabs;
//int col = 0;
display.setTextColor(SSD1306_WHITE); // Draw white text
//display.println("");
char* inString = entry.name();
String stri = String(inString);
stri = stri.substring(0, stri.length());
char* folder = entry.name();
String toString = String(folder); // Convert filename to String
toString = toString.substring(0, stri.length()); // substring to take length + able to ignore extension (if necessary)
toString.toCharArray(inString, toString.length()+1); // Convert back to char array to be stored in char* folderList
folderList[x]=strdup(inString); // strdup = duplicate
Serial.println(folderList[x]); // This is printing all of the folders -> this is the array they're stored in
//display.setCursor(col, 1);
//folderList[x] = Wire.read();
display.println(folderList[x]); // This is printing all of the folders -> this is the array they're stored in
//col = 1 - col; // this creates the vertical line by line
folderCounter++;
//Serial.println(entry.name()); // printLN ln is what prints vertically
if (entry.isDirectory())
//entry.read(folderNameBuff, numTabs); // I think this reads file entry & numTabs contents into folderNameBuff
//store contents into -> folderNameBuff -> I don't think it does.
//store contents into -> fileNameBuff
Serial.println("");
display.display();
entry.close();
returnButton.update();
selectButton.update();
//scrollButton.update();
int fileIndex = 0; // Selected file index
int position = 0; // Encoder position
int previousPosition = 0;
position = myEncoder.read();
// Check for changes in encoder position
if (position != previousPosition)
// Determine direction of rotation
if (position > previousPosition)
// Move down one file/folder
fileIndex++;
Serial.print(">");
delay(100);
// Move up one file/folder
fileIndex--;
Serial.print("<");
for(int n = 0; n < fileCount; n++)
// Wrap around if at end of list
if (fileIndex >= fileCount) {
fileIndex = 0;
} else if (fileIndex < 0) {
fileIndex = fileCount - 1;
fileCount = folderList[n];
for(int j = 0; j < fileIndex; j++)
fileCount = folderList[j];
if(selectButton.fallingEdge())
openSelected();
if(returnButton.fallingEdge())
void openSelected()
//int trackFolderIndex = 0;
//File openPathFile;
//File folderSelect = openPathFile.openNextFile();
//strcpy(folder, storedPath);
//File entry = openPathFile.openNextFile();
//File entry = SD.open(const char *filepath)
display.clearDisplay();
const char *folderPtr = folderList[x];
File entry = SD.open(folderPtr);
display.print(folderPtr);
display.print(":");
display.setCursor(0, 10);
//File folderSelect = currentDirectory.openNextFile();
//presetStr[trackFolderIndex] = folderSelect.name();
//trackFolderIndex++;
if(entry.isDirectory())
strcat(storedPath, "/Folder");
strcpy(storedPath, folderNameBuff); // copy folderNameBuff contents into storedPath
strcpy(storedPath, folderList[x]);
//sprintf(storedPath, folderNameBuff); // folderNameBuff content stored as a string in storedPath buffer
//Serial.println(storedPath); // should print e.g. /Presets/
//storedPath = folderSelect; // this is to say: the selected folder which is a directory is put back into printDir
printDirectory(entry, 0); // loop back with whichever folder has been chosen, and list the contents
if(!entry.isDirectory())
strcat(storedPath, "/File"); // only this prints
strcat(storedPath, fileNameBuff);
//sprintf(storedPath, fileNameBuff); // This seems to hold "nothing" -> don't use
playSample();
//File rootOpen = SD.open(storedPath);
void playSample()
SD.open(storedPath, FILE_READ);
void displayInit()
display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS);
display.setTextSize(1); // Normal 1:1 pixel scale
