On AVR processors, the 8 MHz internal oscillator has a frequency calibration register named OSCCAL, and can be tuned in steps of some size. So, your idea of using the RTC as a frequency reference could work.
Atmel had an application note on how to do that, but it might be hard to find under Microchip ownership.
Here is Arduino code that does that using a 32 kHz crystal on Timer2 as the reference and incidentally creates an RTC. Of course, you can just use the crystal as an interrupt source for your project, as well, but it has the same problem of frequency division as the 8192 Hz source.
// low power BCD RTC using bare bones ATMega328p, no regulator, 3-5V
// update 3/1/2019
// This code creates an RTC formed by Timer2 and a 32768 xtal+2x30 pF caps on OSC pins
// The internal RC oscillator is calibrated by comparison with the 32768 standard,
// Low power operation borrowed heavily from https://www.gammon.com.au/power
// SET FUSES: 8 MHz internal RC clock, LP xtal (32768 Hz) on OSC pins
// S. James Remington 3/2013
//reminder: 8 MHz internal RC
//#define F_CPU 8000000UL
#include <avr/sleep.h>
#include <util/delay.h>
// Global variables for RTC
volatile unsigned char RTC_buf[] = {0, 0, 0, 0, 0, 0}; //initialize BCD digits coding for hh:mm:ss
volatile unsigned int dayno = 0; //days since startup
#define BUF_LEN 20
char buf[BUF_LEN]; //print message buffer
Serial.println("Simple RTC");
pinMode(2, OUTPUT); //LED on PD2
for (int i = 1; i < 4; i++) {
digitalWrite(2, 1);
delay(100);
digitalWrite(2, 0);
delay(900);
// calibrate 8 MHz oscillator using the 32 kHz xtal
OSCCAL_calibrate();
Serial.print("OSCCAL (cal) ");
Serial.println(OSCCAL);
Serial.flush(); //finish printing before turning off USART
//PRR Power Reduction Register (set PRADC after ADCSRA=0)
//Bit 7 - PRTWI: Power Reduction TWI
//Bit 6 - PRTIM2: Power Reduction Timer/Counter2
//Bit 5 - PRTIM0: Power Reduction Timer/Counter0
//Bit 3 - PRTIM1: Power Reduction Timer/Counter1
//Bit 2 - PRSPI: Power Reduction Serial Peripheral Interface
//Bit 1 - PRUSART0: Power Reduction USART0
//Bit 0 - PRADC: Power Reduction ADC
ADCSRA = 0; //disable ADC
// turn off unneeded modules. With Timer0 off, **can't use delay() or millis()**!
PRR |= (1 << PRTWI) | (1 << PRTIM1) | (1 << PRSPI) | (1 << PRADC) | (1 << PRUSART0) ; //need Timer2
// reprogram timer 2 for this application
timer2_init();
char t = 0;
unsigned int batt, h, m, s;
while (1) {
// wake up on Timer2 overflow (1/sec)
// output day, time and cpu voltage on serial monitor every ... (10 seconds now)
if (t != RTC_buf[4]) { //have 10 seconds passed?
t = RTC_buf[4];
s = 10 * RTC_buf[4] + RTC_buf[5]; //format time
m = 10 * RTC_buf[2] + RTC_buf[3];
h = 10 * RTC_buf[0] + RTC_buf[1];
PRR &= ~((1 << PRADC) | (1 << PRUSART0)); //turn on ADC and USART
ADCSRA = (1 << ADEN); //set up ADC properly
ADCSRA |= (1 << ADPS0) | (1 << ADPS1) | (1 << ADPS2); // ADC Prescaler=128
delay(1); //let ADC and USART stabilize
batt = readVcc(); //read battery voltage
// print day, time and battery voltage
snprintf(buf, BUF_LEN, "%u,%02u:%02u:%02u,%u", dayno, h, m, s, batt); //max ~16 characters
Serial.println(buf);
Serial.flush(); //finish printing before going to sleep
// back to sleep with modules off
ADCSRA = 0; //ADC off
PRR |= (1 << PRADC) | (1 << PRUSART0); //turn off ADC and USART
} //end if (t)
set_sleep_mode(SLEEP_MODE_PWR_SAVE);
sleep_enable();
cli(); //time critical steps follow
MCUCR = (1 << BODS) | (1 << BODSE); // turn on brown-out enable select
MCUCR = (1 << BODS); //Brown out off. This must be done within 4 clock cycles of above
sei();
sleep_cpu();
} //end while(1)
// Timer2 Interrupt Service
// 32 kKz / 256 = 1 Hz with Timer2 prescaler 128
// provides global tick timer and BCD binary Real Time Clock
// no check for illegal values of RTC_buffer upon startup!
ISR (TIMER2_OVF_vect) {
// RTC function
RTC_buf[5]++; // increment second
if (RTC_buf[5] > 9)
RTC_buf[5] = 0; // increment ten seconds
RTC_buf[4]++;
if ( RTC_buf[4] > 5)
RTC_buf[4] = 0;
RTC_buf[3]++; // increment minutes
if (RTC_buf[3] > 9)
RTC_buf[3] = 0;
RTC_buf[2]++; // increment ten minutes
if (RTC_buf[2] > 5)
RTC_buf[2] = 0;
RTC_buf[1]++; // increment hours
char b = RTC_buf[0]; // tens of hours, handle rollover at 19 or 23
if ( ((b < 2) && (RTC_buf[1] > 9)) || ((b == 2) && (RTC_buf[1] > 3)) )
RTC_buf[1] = 0;
RTC_buf[0]++; // increment ten hours and day number, if midnight rollover
if (RTC_buf[0] > 2) {
RTC_buf[0] = 0;
dayno++; //count days since startup
// initialize Timer2 as asynchronous 32768 Hz timing source
void timer2_init(void) {
TCCR2B = 0; //stop Timer 2
TIMSK2 = 0; // disable Timer 2 interrupts
ASSR = (1 << AS2); // select asynchronous operation of Timer2
TCNT2 = 0; // clear Timer 2 counter
TCCR2A = 0; //normal count up mode, no port output
TCCR2B = (1 << CS22) | (1 << CS20); // select prescaler 128 => 1 sec between each overflow
while (ASSR & ((1 << TCN2UB) | (1 << TCR2BUB))); // wait for TCN2UB and TCR2BUB to be cleared
TIFR2 = (1 << TOV2); // clear interrupt-flag
TIMSK2 = (1 << TOIE2); // enable Timer2 overflow interrupt
// Read 1.1V reference against AVcc
// EVERY PROCESSOR MUST BE CALIBRATED INDIVIDUALLY!
unsigned int readVcc(void) {
unsigned int result;
// set the reference to Vcc and the measurement to the internal 1.1V reference
ADMUX = (1 << REFS0) | (1 << MUX3) | (1 << MUX2) | (1 << MUX1);
delay(2); // Wait for Vref to settle
ADCSRA |= (1 << ADSC); // Start conversion
while (bit_is_set(ADCSRA, ADSC)); // wait until done
result = ADC;
// two is better than one
result = ADC;
// calibrated for Miniduino board
result = 1195700UL / (unsigned long)result; //1126400 = 1.1*1024*1000
return result; // Vcc in millivolts
// Calibrate the internal OSCCAL byte, using the external 32768 Hz crystal as reference.
void OSCCAL_calibrate(void) //This version specific to ATmegaXX8 (tested with ATmega328)
unsigned char calibrate = 0; //FALSE;
unsigned int temp;
TIMSK1 = 0; //disable Timer1,2 interrupts
TIMSK2 = 0;
ASSR = (1 << AS2); //select asynchronous operation of timer2 (32,768kHz)
OCR2A = 200; // set timer2 compare value
TCCR1A = 0;
TCCR1B = (1 << CS11); // start timer1 with prescaler 8
TCCR2A = 0;
TCCR2B = (1 << CS20); // start timer2 with no prescaling (ATmega169 use TCCR2A!)
while (ASSR & ((1 << TCN2UB) | (1 << TCR2BUB))); //wait for TCN2UB and TCR2BUB to be cleared
delay(5000); //5 seconds to allow xtal osc to stabilize
while (!calibrate)
cli(); // disable global interrupts
TIFR1 = 0xFF; // clear TIFR1 flags
TIFR2 = 0xFF; // clear TIFR2 flags
TCNT1 = 0; // clear timer1 counter
TCNT2 = 0; // clear timer2 counter
while ( !(TIFR2 & (1 << OCF2A)) ); // wait for timer2 compareflag
TCCR1B = 0; // stop timer1
sei(); // enable global interrupts
if ( (TIFR1 & (1 << TOV1)) ) temp = 0xFFFF; //overflow, load max
else temp = TCNT1;
if (temp > 6150) //expect about (1e6/32768)*201 = 6134 ticks
OSCCAL--; //RC oscillator runs too fast, decrease OSCCAL
else if (temp < 6120)
OSCCAL++; //RC oscillator runs too slow, increase OSCCAL
else calibrate = 1; //done
TCCR1B = (1 << CS11); // (re)start timer1
} //end while(!calibrate)
} //return
