HiTec Dig. Servo - Example works, My code doesn't
I tried the example sweep and my servo works great, I tried my own example and it doesn't. I am assuming it is related to the timing. I have a sensor that when it goes low, I want the servo to swap where it was (180 to 0, 0 to 180). The LCD shows the updated sense count, so I know the sensor is working. The example sweep works, so I know the servo is working. Where am I going wrong?
#include <LiquidCrystal.h>
#include <Servo.h>
LiquidCrystal lcd(22, 23, 31, 32, 33, 34);
Servo myservo;
int inPin = 43;
int outPin = 13;
int reading;                // the current reading from the input pin/sensor
int sense_count=0;     // sensor count
int servo_val=0;         // servo value
  pinMode(inPin, INPUT);
  pinMode(outPin, OUTPUT);
  lcd.begin(20, 4);
  lcd.clear();
  lcd.print("Servo Test v0.1");
  myservo.attach(52);
  myservo.write(0);
  delay(15);
  reading = digitalRead(inPin);
  lcd.setCursor(14, 3);
  if (reading == LOW) {
    sense_count++;
    lcd.print(sense_count);
    delay(15);
    if (servo_val == 0) {
      servo_val = 180;
      servo_val = 0;
    myservo.write(servo_val);
    delay (15);
I am aware that the default min/max for the servo in the Servo.h library are not the HiTec recommended values of 900 and 2100. But, when I try to pass those initially in myservo.attach(52, 900, 2100), my servo goes crazy.
15ms for a 180 degree sweep?
That's a fast servo.
But what does it do?
Your idea of "works" isn't clear.
With the Example code for Sweep, it works.
With this code, the servo doesn't move a bit.
Is 15ms per a degree the actual calculation? So that is 2700ms for a 180 degree swap?
Thanks.
15ms is the time you're allowing the servo to travel 180 degrees, before you're reading the input pin again.
There is no "calculation".
