HM10 Ibeacon scanning
Hello guys,
I am trying to scan ibeacons using HM10 bluetooth module and arduino. When i pass "AT+DISI?" command from the serial monitor, the module responds positively and scans the BLEs around me, everytime I type in that command. However when I try to enter the command through a code using looping for continuous scanning, it scans only twice or thrice and then stops scanning. I have added my code here too. Please help.
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(10,11);
char disi_result[400];
int top=0;
int d1=0;
int i=0;
struct devices {
unsigned int major=0;
unsigned int minor=0;
unsigned int power=0;
int rssi=0;
devices device[4];
Serial.begin(38400);
BTSerial.begin(9600);
start_at();
void loop(){
if(d1==0)
Serial.println("Scanning started");
BTSerial.write("AT+DISI?");
d1=1;
if(d1==1){
if (BTSerial.available() ){
while(BTSerial.available()){
disi_result=char(BTSerial.read());
i++;
int j;
String str="";
for(j=i-8;j<=i;j++)
str=str+disi_result[j];
if(str=="OK+DISCE" ){
d1=2;
if(d1==2)
int j=0;
for(j=0;j<=i;j++)
Serial.print( disi_result[j]);
i=0;
d1=0;
void start_at(){
String c="";
do{
BTSerial.print("AT");
if (BTSerial.available())
c=c+char(BTSerial.read());
}while(c!="OK");
You are probably running out of memory. There is NO reason to wrap the strings you read from the serial port in Strings. So, quit doing that.
