I want to know if I am thinking of a feasible solution to my problem...I have been able to build a solar charger to keep a waterpump filling our 5000 gal house supply tank. We are having one of our worst draughts in memory.
Using good advice here and some similar projects found online my simple system design seems to work EXCEPT on hot sunny days (when we need it most of course).
I watched it yesterday almost continuously from about 10 am when the temperature was still moderate...it ran fine until about 11 ish. Then the pump would sputter air. There are no air leaks in the supply line. BUT that line is some 600 meters long and 20 mm (3/4 in) dia. Water will actually dribble to the pump by syphon action but it is too slow to be useful.
If there is no air leaking into the line AND it only happens when hot is the reduced pressure (this pump has a flow rate of about 200 ml per minute and can lift water to fill and empty line ... i'm guess but say about 2 meters.) so is it possible/likely that the hot water is boiling under reduced pressure?
Although the pump can lift water when it hits this problem all flow stops. Maybe water vapor is continuously boiling off and that vapor is all the pump gets a bite of?
OK if youre still with me here is my question: Is there a way to sense when water in the line is boiling or preferably just about to boil? My thought is to use a sensor to control the pump speed (24 - 90 VDC, ~0.4 amp).
If i don't do something I believe i will destroy the pump, it is an FMI lab pump that I've used for ages in my little home lab...now it is keeping us wet. a vid here shows the clever no-checkvalve piston action if interested: http://fluidmetering.com/
thanks in advance
