How can i control LED with mini on/off push button?
I'm working on a project where a mini on/off push button would change the LED strip color each time the button is pressed. For now I would like to indicate red, green and blue to understand how it works. I'm using:
  • an Arduino Nano Every
  • Addressable LED strip
  • Mini on/off push button
  • 330 ohm resistor
  • 100 uF capacitor
Hoping somebody can help me with this.
Thank you.
What help are you looking for?
What exact strip do you have? Post a link to where you got it, please.
Look at the state change detection example. Use the buttonPushCounter variable to select a color using a switch case structure.
See also my state change for active low switches tutorial.
Start with this tutorial:
StateChangeDetection
Maybe this example code will be of use. It uses the state change detection method applied to a pushbutton (momentary) switch. Each press increments a counter up to a maximum number above which the counter is reset to 0. A switch case structure changes the strip color based on the counter value.
   The circuit:
   - pushbutton attached to pin 12 from ground
   - the internal pullup on pin 12 is enabled
   - LED attached from pin 13 to ground (or use the built-in LED on most
    Arduino boards)
   - A WS2812 LED strip is connected to pin 6
#include <FastLED.h>
// this constant won't change:
const byte  buttonPin = 12;    // the pin that the pushbutton is attached to
const byte ledPin = 13;       // the pin that the LED is attached to
const byte DATA_PIN_1 = 6; // led strip data pin
const byte NUM_LEDS_1 = 20;
CRGB leds_1[NUM_LEDS_1];
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
   // initialize the button pin as a input:
   pinMode(buttonPin, INPUT_PULLUP);
   // initialize the LED as an output:
   pinMode(ledPin, OUTPUT);
   // initialize serial communication:
   LEDS.addLeds<WS2812, DATA_PIN_1, GRB>(leds_1, NUM_LEDS_1);
   static bool lastButtonState = 1;     // previous state of the button
   static unsigned long timer = 0;
   unsigned long interval = 50;
   if (millis() - timer >= interval)
      timer = millis();
      // read the pushbutton input pin:
      bool buttonState = digitalRead(buttonPin);
      // compare the buttonState to its previous state
      if (buttonState != lastButtonState)
         // if the state has changed, increment the counter
         if (buttonState == LOW)
            // if the current state is LOW then the button went from off to on:
            buttonPushCounter++;
            if (buttonPushCounter > 4)
         // save the current state as the last state, for next time through the loop
         lastButtonState = buttonState;
      // select strip color with pushButtonCounter value
      //Serial.print("buttonPushCounter: ");
      //Serial.println(buttonPushCounter);
      switch (buttonPushCounter)
         case 0:
            for (int n = 0; n < NUM_LEDS_1; n++)
               leds_1[n] = CRGB::Red;
         case 1:
               leds_1[n] = CRGB::Purple;
         case 2:
               leds_1[n] = CRGB::Blue;
         case 3:
               leds_1[n] = CRGB::Green;
         case 4:
               leds_1[n] = CRGB::Cyan;
         default:
               leds_1[n] = CRGB::Black;
   FastLED.show();
Hello luminerd
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
thank you, these tutorials are really helpful to make understand how switch works
Wow this really gave me a solution, works seamlessly. I'm glad that i'm able to change the variants of color by itself. Thank you so much :slight_smile:
