How can I get this kit car forward then stop?
Hi, I'm a total newbie with arduino, but have been coding for about 2 semesters now, so I get most of the basics.
I've got my little arduino car kit and it run forward and backward fine.
Now I'm trying to get it to run for 5 seconds forward then stop, but I'm not quite sure how to set that up in my code.
This is what I have so far...
#include <Adafruit_MotorShield.h>
//create motor shield object and 4 motors
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *Motor1 = AFMS.getMotor(1);
Adafruit_DCMotor *Motor2 = AFMS.getMotor(2);
Adafruit_DCMotor *Motor3 = AFMS.getMotor(3);
Adafruit_DCMotor *Motor4 = AFMS.getMotor(4);
  Serial.println("Riverbot DC Motor test!");
  //start the motor shield
  if (!AFMS.begin()) {
    Serial.println("Could not find Motor Shield. Check wiring");
    while (1);
  Serial.println("Motor Shield found");
    //set motor speed to 100 (max=255)
    Motor1->setSpeed(100);
    Motor2->setSpeed(100);
    Motor3->setSpeed(100);
    Motor4->setSpeed(100);
    Motor1->run(FORWARD);
    Motor2->run(FORWARD);
    Motor3->run(FORWARD);
    Motor4->run(FORWARD);
    delay(3000);
Do you know how to use millis to determine when 5 seconds have passed?
What happens when you set the delay() to 5000 and then Motor1->run(RELEASE), etc?
Ponder this code for a while:
bool expired;
unsigned long stopTime;
   pinMode(LED_BUILTIN, OUTPUT);
   digitalWrite(LED_BUILTIN, LOW);
   expired = false;
   stopTime = millis() + 5000;
   if( !expired  && millis() > stopTime ) {
      digitalWrite(LED_BUILTIN, HIGH);
      expired = true;
void setup(){
    while (1);
    delay(5000);
    Motor1->run(STOP);
    Motor2->run(STOP);
    Motor3->run(STOP);
    Motor4->run(STOP);
void loop(){}
