How can I increase precision of float display in the Serial Monitor?
Hello,
I am using the Serial Monitor as a troubleshooting tool for my sketch. I must verify my math among other things. The monitor won't display more than 2 decimal places when reading a float var. I assume it is rounding. I could probably modify it if I just knew where 'rounding' is located. I've searched Arduino.cc, the forum, googled it and can't find anything. Has anyone else solved this problem?
Thanks in advance,
-oldfox-
"If it ain't broke, fix it 'til it is."
1oldfox:
Hello,
Thanks in advance,
-oldfox-
No you just add a second optional argument to the serial.print statement that tells it how many digits to the right of the decimal place you wish to be printed:
Syntax
Serial.print(val)
Syntax
Serial.print(val)
Serial.print(val, format)
Parameters
val: the value to print - any data type
format: specifies the number base (for integral data types) or number of decimal places (for floating point types)
Parameters
So assuming your val is a floating point variable and you wished to print four digits after the decimal point the statement would look like this:
Serial.print(val, 4);  // print floating point variable showing four digits after decimal point.
Lefty
Thanks Lefty, you are "righty"
And Keith, thanks also. I don't know how I missed that one. Old eyes, broken ears and questionable brain works. :roll_eyes:
retrolefty gave you the fish, I tried to teach you how... 8^)
This is a quirk with the Print method, apparently.
Check the line here : Arduino/Print.cpp at 9d1302307528622ed5d1d2f838bbce1c85301f94 · arduino/Arduino · GitHub
So, basically, if you want to print a float, you declare it as a "double" type, and then call Serial thusly :
Serial.println(double val , int digits);
and you should have what you need
ankitdaf:
I don't see how a clearly defined method is a "quirk"
But how to store the value of Serial.print(floantN,L) in a variable ?
