How can I measure negative temperatures with DS18B20
Hello, guys. I'm using DS18B20 sensors to monitorize a freezer, but I'm having some issues. My temperatures are getting lower instead of getting high (becoming less negative) when I cut off the energy. Could you look at my code to check with everything is ok? Or should I suppose this is a library bug?
#include <OneWire.h>
#include <DallasTemperature.h>
#include "EmonLib.h"
EnergyMonitor emon1;
#define ONE_WIRE_BUS 10 // Conectar o pino central dos sensores ao pino 10 do Arduino
OneWire oneWire(ONE_WIRE_BUS);
// Setup a oneWire instance to communicate with any OneWire devices
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
DeviceAddress one_Thermometer = { 0x28, 0xFF, 0xAC, 0x17, 0x41, 0x04, 0x00, 0x45  };
DeviceAddress two_Thermometer = {0x28, 0xFF, 0x12, 0x1A, 0x43, 0x04, 0x00, 0x7A };
DeviceAddress three_Thermometer = { 0x28, 0xFF, 0x31, 0x18, 0x43, 0x04, 0x00, 0xCB };
int rede = 110.0;
//Pino analógico do arduino ligado ao sensor SCT
int pino_sct = 1;
int row=0;
int LABEL=1;
void setup(void)
  // start serial port
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(one_Thermometer, 10);
  sensors.setResolution(two_Thermometer, 10);
  sensors.setResolution(three_Thermometer, 10);
  emon1.current(pino_sct, 29);
  Serial.println("CLEARDATA");
  Serial.println("LABEL, TIME, Sensor_1 (F), Sensor_2 (F), Sensor_3 (F),Current (A), Power (W)");
  delay(1000);//Aguarda 1 seg antes de acessar as informações dos sensores
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC == -127.00)
    Serial.print("Erro ao ler temperatura !");
    Serial.print(tempC);
void loop(void)
  row++;
  double Irms = emon1.calcIrms(1480); //Calcula a corrente
  sensors.requestTemperatures();   // requisita leituras dos sensores
  Serial.print("DATA,TIME,");
  printTemperature(one_Thermometer);
  Serial.print(","); // pula pra próxima coluna
  printTemperature(two_Thermometer);
  printTemperature(three_Thermometer);
  Serial.print(","); //pula pra próxima coluna
  Serial.print(Irms); // Irms;
  Serial.print(",");
  Serial.print(Irms*rede);
  Serial.print(",");
  Serial.println(row);
    if (row>15000)
    { row=0;
      Serial.println("row, SET, 2");
  delay(1000); // tempo de medidas
Hi, Dio!
I am a newbie as well. But I've found these two related topics. Maybe you can find out the response you need reading the topics. Good luck!
Ed
https://www.raspberrypi.org/forums/viewtopic.php?f=37&t=91982
http://bradsduino.blogspot.com.br/2013/03/measuring-negative-temperatures-with.html
