How can i solve for this eror?
Sketch uses 5936 bytes (19%) of program storage space. Maximum is 30720 bytes.
Global variables use 476 bytes (23%) of dynamic memory, leaving 1572 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM6" -b115200 -D "-Uflash:w:C:\Users\user\AppData\Local\Temp\arduino\sketches\43D912B884510F403928432EC8D36B12/sketch_apr26a.ino.hex:i"
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\user\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM6": The system cannot find the file specified.
avrdude done.  Thank you.
Failed uploading: uploading error: exit status 1
We would need the code to provide much help. However I suggest you at least look at the serial port syntax. It will be on the Arduino Documentation website.
my bad. i forgot to choose the processor LMAO :skull:
I do that often. Please, mark your topic "solved."
