How did I debug output to terminal (when no serial port available)?
Hello
I'm doing a project that involves writing to an LCD using the Arduino/Adafruit LCD library and also writes to and reads from a howebrew MIDI interface transmitting/receving on pins TX/RX and using the FortySevenEffects MIDI library.
This means I can't serial print to the IDE's debug console as the serial port is in use (and at a different baud rate to 9600 as it's MIDI).
Now a few years ago I remember doing a similar project and I found some kind of solution where I could start a CLI program in terminal (on OSX) and send debug messages to that from my code? I've been Googling for an hour or so and I just can't remember what it was.
Maybe something to do with SoftSerial?
I remember it being quite straightforward. Open terminal, start a program. No hoops to jump through from IDE. A simple line of code would send any info of my choosing.
Does anybody know how to do this or what I might be thinking of?
Thanks
Jim
SoftwareSerial on 2 currently unused pins, a TTL to RS232 converter and a terminal emulator such as PuTTY and you are in business
UKHeliBob:
Probably have better luck with a TTL to USB COM Port converter as few computers these days have a real RS232 port anymore.
Thanks for prompt reply that sounds like a great solution (and the right one!) but I don't think it's what I was doing before.
There was no additional hardware needed as far as I can remember.
In fact I just found a clue in some old source code
// debug @ 31250 bps
// see miniterm.py http://www.sinneb.net/?p=136
// Serial.println(note,DEC);
// Serial.println(veloc,DEC); */
But the link is dead
Hmm ... I've also got a vague memory of using two Arduino boards once, for something! ... might I have been using a second board as " a TTL to RS232 converter" as you're suggesting?
Very true. The reference to RS232 must have come from deep in my suppressed past memories of dealing with the horrors of RS232 interfacing
