More seriously, this has caused a most confusing issue, likely to do with the function prototypes the IDE creates for you:
void buzz(int 2)
void buzz(int 2)
I tried auto-format and it didn't say/do anything.
Frank-duino:
When I do it I am warned "Auto Format Cancelled: Too many right curly braces"
I have tried to verify your code and it seems to be a complete mess with names used twice and names used that are not declared.
But the first big problem is void buzz(int 2)
I have no idea what you think that does but there should be a variable name where you have the "2". However (consistent with the other mess-ups) you don't actually use the value in the function.
Then the next big problem is
void buzzer() {
digitalWrite(10, HIGH);
which is trying to define a function within the setup() function.
Again I have no idea what you want void buzzer() to do so I can't advise whether to delete it or to move it outside setup().
I could go on ... but you will learn more if you do it yourself.
...R
Robin2:
Then the next big problem isvoid buzzer() {
which is trying to define a function within the setup() function. Again I have no idea what you want void buzzer() to do so I can't advise whether to delete it or to move it outside setup(). I could go on ... but you will learn more if you do it yourself. ...R
i guess i'm guilty for that one;
http://forum.arduino.cc/index.php?topic=222865.msg1617120#msg1617120
Ok, I ran the auto-format again and I just saw the exact same warning. What does it mean....
If it's the same one as quoted above, it probably means there's more than an ample sufficiency of these '}'
Yeah, I deleted one of the curly brackets from the bottom and I don't have the error anymore.
What should I do now?
Frank-duino:
what do you want to do now ?
before you dive into code that you're obviously still not comfortable with, try a really simple "sketch" - NOT Arduino code, just plain English.
write out in words what you want to do;
eg.
in the code that you have, or we hope, rewrite - add comments to say/explain(to yourself & others) what it does, or at least what you think it is doing.
and then post it here and we can guide you better if there's any misunderstanding.
retronet_RIMBA1ZO:
Excellent advice.
...R
