Hey guys, I was wondering if you could help me with, what i think, is a simple problem that has me quite stuck! (Quite embarrassed!)
How do i get it to turn my LED off after it has flashed 10 times??
I will be using this to control my solenoid but for now, a LED will do!
This is my closest attempt so far:
const int solenoid = 3;
int redled = 13;
int wait = 10; // 10ms internal crossFade delay; increase for slower fades
int hold = 0; // Optional hold when a color is complete, before the next crossFade
int DEBUG = 1; // DEBUG counter; if set to 1, will write values back via serial
int loopCount = 60; // How often should DEBUG report?
int repeat = 3; // How many times should we loop before stopping? (0 for no stop)
int j = 0; // Loop counter for repeat
// initialize the digital pin as an input:
pinMode(redled, INPUT);
void loop(){
if (repeat) { // Do we loop a finite number of times?
j += 3;
if (j >= repeat) { // Are we there yet?
digitalWrite(redled,HIGH);
delay(50);
digitalWrite(redled,LOW);
delay(50);
exit(j); // If so, stop.
I really thought that this would work? What do you think? why does it only flash once??
int redled = 13;
int repeat =10; // How many times should we loop before stopping? (0 for no stop)
void loop(){
if (repeat <=10) { // Do we loop a finite number of times?
repeat--;
delay(50);
digitalWrite(redled, LOW);
delay(50);
You can also reverse the logic and have repeat start at 0 and build up to 10 in the loop.
It is still not working though, I copied your code and ran it but it doesn't stop after it has flashed 10 times?? What else can you suggest? Are there other ways of doing this? I've been looking at codes with "i" and "j" s but it is just too abstract for me to understand.
repeat--;
delay(50);
delay(50);
should be:
if (repeat > 0) { // Do we loop a finite number of times?
repeat--;
delay(50);
delay(50);
Since repeat starts at 10, and is decremented, we want the led to come on for 50 milliseconds and then go off for 50 milliseconds only while repeat is positive. As soon as repeat goes negative, quit.
sorry there was a simple error i overlooked. The pinMode() should be output not input. that was the main problem.
int redled = 13;
int repeat = 0; // How many times should we loop before stopping? (0 for no stop)
pinMode(redled, OUTPUT);
void loop(){
if (repeat <=10)
repeat++;
digitalWrite(redled, HIGH);
I just have a quick question to help me understand this procedure:
So when i put " int repeat = 10 " , am i only limited to using the text 'repeat' or can write anything there? Is it the layout of the code below what controls the loop?
repeat--;
I am just wondering if you could have multiple loops, looping different no of times like:
Ok Ok, I like this. I was just playing around with the looping and decided to add another loop 1 second after the first one had stopped... I thought a delay would do, but it combined the loops together and added a second inbetween every two flashes.
repeat--;
repeat--;
I tried changing the repeat to cycle but i got the same result... any thoughts??
Sorry for the harassment! You don't need to reply, you have done enough already!
The loop function is called in an infinite loop. What we were helping you do was to make loop do something each of the first 10 times it was called.
The changes you've made change what it does each time it is called.
If you want to have it do one thing (or set of things) the first 10 times it is called, and do something else (or set of things) the next n times it is called, you can do this:
int firstCount = 10;
int secondCoun t = 33;
if(firstCount > 0)
// Do the first thing(s)
firstCount--;
if(secondCount > 0 && firstCount <= 0)
// Do the second thing(s)
secondCount--;
Also note that there is a difference (in C) between saying "repeat++;" and "++repeat;"...
Used alone, they mean (virtually) the same thing, but used this way:
if (repeat++ > 10) { // do something
vs
if (++repeat > 10) { // do something
will give you slightly different results (and may even lead to some hair pulling when used in a for() loop!) - I leave figuring out what those results are as an exercise for the reader...
(hint: this is called the increment operator in C)
In that case you may want to do this as a for() statement rather then if(). In this case the first for() statement will run till r=9. Keep in mind the count starts at 0 not 1 so it will flash 10 times. Once that is complete then it will move on to the next for() statement. After that it starts right back at the top again.
int redled = 13;
void loop(){
for(int r=0; r<10; r++)
if(r<10)
for(int s=0; s<10; s++)
if(s<10)
delay(100);
delay(100);
I realize that this is a typo but just to keep novices from being confused
repeat-- is the same as repeat = repeat - 1, which is not the same as repeat = 1-repeat
The repeat++ takes the value of repeat and adds 1 and stores the new value back to repeat. Likewise repeat-- subtracts one.
what does the " r " and " s " refer to your code digimike? Can these letters be anything?
Also I thought this line above would mean you could make the loops stop after x no. of times? As i tried it and it didn't work? Do i need to add in something totally different to achieve that?
Simply declares a variable called "repeat" and initialises it to the value zero.
You can only use it loop zero times if you use it in a comparison against some other variable that is actually keeping track of the number of times you have looped.
How would i begin to achieve this if it is with the same variable? Or does that not work?? I have been trying with the LEDcolorMixerWith3Pots example and i am now thoroughly confused! Can you point me in the right direction please?
goal: To make it stop after it has looped x amount of times? (Just using an LED and giving it patterns with different loops)
The simplest way of making something stop after looping 'n' times is with a "for" loop in "setup()", and nothing at all in "loop ()":
const int loopTimes = 10;
void setup ()
// setup pinModes and stuff here:
for (int i = 0; i < loopTimes; ++i) {
//whatever you want to do in here
void loop ()
//nothing, nada, rien.
So. Using the example digimike gave, as i like this one and seem to understand it, i should be able to make it complete the loops 10 times all within setup?!
int redled = 13;
for (int i = 0; i< loopTimes; ++1){
if(r<15)
delay(50);
delay(50);
delay(3000);
if(s<10)
delay(100);
delay(100);
void loop(){
" I get this error: Ivalue required as increment operand "
I can't get it to work and I don't know how to correct it to test what i want! Would you not have to call it in void loop to activate the loop?!
Any help / advice you could share with me with looping loops?! I'm sorry if this is all very silly!
