How do I add up to 50 more users?
I got this code from Fingerprint Based Biometric Attendance System using Arduino - SovanHax
It's currently set to only 10 users
#include <Adafruit_Fingerprint.h>
#include<EEPROM.h> //command for storing data
#include<LiquidCrystal.h> //lcd header file
int Contrast = 100;
LiquidCrystal lcd(9, 8, 5, 4, 3, 2);  // 8,9,10,11,12,13 ORIGINAL ARRANGEMENT
#include <SoftwareSerial.h>
SoftwareSerial fingerPrint(12, 13); //for tx/rx communication between arduino & r305 fingerprint sensor
#include <Wire.h>
#include "RTClib.h" //library file for DS3231 RTC Module
RTC_DS3231 rtc;
uint8_t id;
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&fingerPrint);
#define register_back 14
#define delete_ok 15
#define forward 16
#define reverse 17
#define match 5
#define indFinger 7
#define buzzer 5
#define records 10 // 10 for 10 user
int user1,user2,user3,user4,user5,user6,user7,user8,user9,user10; // review
// user11,user12,user13,user14,user15,user16,user17,user18,user19,user20
// user21,user22,user23,user24,user25,user26,user27,user28,user29,user30
// user31,user32,user33,user34,user35,user36,user37,user38,user39,user40
// user41,user42,user44,user44,user45,user46,user47,user48,user49,user50
DateTime now;
delay(700); //1000
// lcd.begin(16,2);
analogWrite(6,Contrast);
     lcd.begin(16, 2);
pinMode(register_back, INPUT_PULLUP);
pinMode(forward, INPUT_PULLUP);
pinMode(reverse, INPUT_PULLUP);
pinMode(delete_ok, INPUT_PULLUP);
pinMode(match, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
pinMode(indFinger, OUTPUT);
digitalWrite(buzzer, LOW);
if(digitalRead(register_back) == 0)
// digitalWrite(buzzer, HIGH);
delay(300);//500
lcd.clear();
lcd.print("Please wait !");
lcd.setCursor(0,1);
lcd.print("Downloding Data");
Serial.println("Please wait");
Serial.println("Downloding Data..");
Serial.print("S.No. ");
for(int i=0;i<records;i++)
delay(300);//500
Serial.print(" User ID");
Serial.print(i+1);
Serial.print(" ");
int eepIndex=0;
for(int i=0;i<30;i++)
if(i+1<10)
Serial.print('0');
Serial.print(i+1);
Serial.print(" ");
eepIndex=(i*7);
download(eepIndex);
eepIndex=(i*7)+210;
download(eepIndex);
eepIndex=(i*7)+420;
download(eepIndex);
eepIndex=(i*7)+630;
download(eepIndex);
eepIndex=(i*7)+840;
download(eepIndex);
eepIndex=(i*7)+1050;
download(eepIndex);
eepIndex=(i*7)+1260;
download(eepIndex);
eepIndex=(i*7)+1470;
download(eepIndex);
eepIndex=(i*7)+1680;
download(eepIndex);
if(digitalRead(delete_ok) == 0)
lcd.clear();
lcd.print("Please Wait");
lcd.setCursor(0,1);
lcd.print("Reseting.....");
for(int i=1000;i<1005;i++)
EEPROM.write(i,0);
for(int i=0;i<841;i++)
EEPROM.write(i, 0xff);
lcd.clear();
lcd.print("System Reset");
delay(700);//1000
lcd.clear();
lcd.print(" Fingerprint ");
lcd.setCursor(0,1);
lcd.print("Attendance System");
delay(1000);//2000
lcd.clear();
delay(300);//500
for(int i=1000;i<1000+records;i++)
if(EEPROM.read(i) == 0xff)
EEPROM.write(i,0);
finger.begin(57600);
lcd.clear();
lcd.print("Finding Module..");
lcd.setCursor(0,1);
delay(1000);//2000
if (finger.verifyPassword())
Serial.println("Found fingerprint sensor!");
lcd.clear();
lcd.print(" Module Found");
delay(1000);//2000
Serial.println("Did not find fingerprint sensor :(");
lcd.clear();
lcd.print("Module Not Found");
lcd.setCursor(0,1);
lcd.print("Check Connections ");
while (1);
if (! rtc.begin())
Serial.println("Couldn't find RTC");
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
if (rtc.lostPower())
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(2024, 2, 25, 11, 10, 30));
// This line sets the RTC with an explicit date & time, for example to set
// June 7, 2018 at 11am you would call:
// rtc.adjust(DateTime(2018, 6, 7, 11, 0, 0));
lcd.setCursor(0,0);
lcd.print(" Press Match to ");
lcd.setCursor(0,1);
lcd.print(" Start System");
delay(1300);//3000
user1=EEPROM.read(1000);
user2=EEPROM.read(1001);
user3=EEPROM.read(1002);
user4=EEPROM.read(1003);
user5=EEPROM.read(1004);
lcd.clear();
digitalWrite(indFinger, HIGH);
now = rtc.now();
lcd.setCursor(0,0);
lcd.print("Time: ");
lcd.print(now.hour(), DEC);
lcd.print(':');
lcd.print(now.minute(), DEC);
lcd.print(':');
lcd.print(now.second(), DEC);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("Date: ");
lcd.print(now.day(), DEC);
lcd.print('/');
lcd.print(now.month(), DEC);
lcd.print('/');
lcd.print(now.year(), DEC);
lcd.print(" ");
delay(300);//500
int result=getFingerprintIDez();
if(result>0)
digitalWrite(indFinger, LOW);
delay(100);
lcd.clear();
lcd.print("ID:");
lcd.print(result);
lcd.setCursor(0,1);
lcd.print("Please Wait....");
delay(800);//1000
attendance(result);
lcd.clear();
lcd.print("Attendance ");
lcd.setCursor(0,1);
lcd.print("Registered");
delay(800);//1000
return;
checkKeys();
delay(200);//300
// dmyyhms - 7 bytes
void attendance(int id)
int user=0,eepLoc=0;
if(id == 1)
eepLoc=0;
user=user1++;
else if(id == 2)
eepLoc=210;
user=user2++;
else if(id == 3)
eepLoc=420;
user=user3++;
else if(id == 4)
eepLoc=630;
user=user4++;
else if(id == 5)
eepLoc=0;
user=user5++;
else if(id == 6)
eepLoc=840;
user=user5++;
else if(id == 7)
eepLoc=1050;
user=user7++;
else if(id == 8)
eepLoc=1260;
user=user8++;
else if(id == 9)
eepLoc=1470;
user=user9++;
else if(id == 10)
eepLoc=1680;
user=user8++;
/*else if(id == 5) // fifth user
eepLoc=840;
user=user5++;
return;
int eepIndex=(user*7)+eepLoc;
EEPROM.write(eepIndex++, now.hour());
EEPROM.write(eepIndex++, now.minute());
EEPROM.write(eepIndex++, now.second());
EEPROM.write(eepIndex++, now.day());
EEPROM.write(eepIndex++, now.month());
EEPROM.write(eepIndex++, now.year()>>8 );
EEPROM.write(eepIndex++, now.year());
EEPROM.write(1000,user1);
EEPROM.write(1001,user2);
EEPROM.write(1002,user3);
EEPROM.write(1003,user4);
// EEPROM.write(4,user5); // figth user
void checkKeys()
lcd.clear();
delay(800);//1000
while(digitalRead(register_back) == 0);
Enroll();
else if(digitalRead(delete_ok) == 0)
lcd.clear();
delay(800);//1000
delet();
void Enroll()
int count=1;
lcd.clear();
lcd.print("Enter Finger ID:");
while(1)
lcd.setCursor(0,1);
lcd.print(count);
if(digitalRead(forward) == 0)
count++;
if(count>records)
count=1;
delay(300);//500
else if(digitalRead(reverse) == 0)
count--;
if(count<1)
count=records;
delay(300);//500
id=count;
getFingerprintEnroll();
if(EEPROM.read(i) != 0xff)
EEPROM.write(i, id);
return;
else if(digitalRead(register_back) == 0)
return;
void delet()
int count=1;
lcd.clear();
lcd.print("Enter Finger ID");
while(1)
lcd.setCursor(0,1);
lcd.print(count);
count++;
if(count>records)
count=1;
delay(300);//500
count--;
if(count<1)
count=records;
delay(300);//500
id=count;
deleteFingerprint(id);
if(EEPROM.read(i) == id)
return;
return;
uint8_t getFingerprintEnroll()
int p = -1;
lcd.clear();
lcd.print("finger ID:");
lcd.print(id);
lcd.setCursor(0,1);
lcd.print("Place Finger");
delay(1000);//2000
while (p != FINGERPRINT_OK)
p = finger.getImage();
switch (p)
case FINGERPRINT_OK:
Serial.println("Image taken");
lcd.clear();
lcd.print("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No Finger");
lcd.clear();
lcd.print("No Finger Found");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
lcd.clear();
lcd.print("Comm Error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
lcd.clear();
lcd.print("Imaging Error");
default:
Serial.println("Unknown error");
lcd.clear();
lcd.print("Unknown Error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
lcd.clear();
lcd.print("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
lcd.clear();
lcd.print("Image too messy");
return p;
lcd.clear();
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
lcd.clear();
lcd.print("Feature Not Found");
return p;
case FINGERPRINT_INVALIDIMAGE:
lcd.clear();
return p;
default:
lcd.clear();
return p;
Serial.println("Remove finger");
lcd.clear();
lcd.print("Remove Finger");
delay(1000);//2000
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
lcd.clear();
lcd.setCursor(0,1);
lcd.print(" Again");
while (p != FINGERPRINT_OK) {
switch (p) {
Serial.print(".");
default:
return;
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
lcd.clear();
lcd.print(" Finger Stored!");
delay(1000);//2000
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
else {
return p;
int getFingerprintIDez()
uint8_t p = finger.getImage();
if (p != FINGERPRINT_OK)
return -1;
p = finger.image2Tz();
return -1;
p = finger.fingerFastSearch();
lcd.clear();
lcd.print("Finger Not Found");
lcd.setCursor(0,1);
lcd.print("Try Later");
delay(1000);//2000
return -1;
// found a match!
Serial.print("Found ID #");
Serial.print(finger.fingerID);
return finger.fingerID;
uint8_t deleteFingerprint(uint8_t id)
uint8_t p = -1;
lcd.clear();
lcd.print("Please wait");
p = finger.deleteModel(id);
Serial.println("Deleted!");
lcd.clear();
lcd.print("Finger Deleted");
lcd.setCursor(0,1);
lcd.print("Successfully");
delay(800);//1000
Serial.print("Something Wrong");
lcd.clear();
lcd.print("Something Wrong");
lcd.setCursor(0,1);
lcd.print("Try Again Later");
delay(1000);//2000
return p;
void download(int eepIndex)
if(EEPROM.read(eepIndex) != 0xff)
Serial.print("T->");
if(EEPROM.read(eepIndex)<10)
Serial.print('0');
Serial.print(EEPROM.read(eepIndex++));
Serial.print(':');
Serial.print('0');
Serial.print(':');
Serial.print('0');
Serial.print(" D->");
Serial.print('0');
Serial.print('/');
Serial.print('0');
Serial.print('/');
Serial.print(EEPROM.read(eepIndex++)<<8 | EEPROM.read(eepIndex++));
Serial.print("---------------------------");
Serial.print(" ");
From your link:
  • Admin Features : For administrative purposes, the system may include an additional level of security through a keypad, enabling authorized personnel to access attendance records or add new users.
I doubt this works with 10 users...
else if (id == 6)
  eepLoc = 840;
  user = user5++;
else if (id == 7)
  eepLoc = 1050;
  user = user7++;
else if (id == 8)
  eepLoc = 1260;
  user = user8++;
else if (id == 9)
  eepLoc = 1470;
  user = user9++;
else if (id == 10)
  eepLoc = 1680;
  user = user8++;
Can you explain why it won't? I'm kind of confused at the moment
Although I tried it. It did
Is the code you posted the code you got, or the code after you started trying to make it work for sixty users?
Please say, or post the original unmodified sketch.
In any case, what you might wanna learn about is
arduino functions
and
arduino array variables
both those search terms will turn up official reasonably good introductions to those key programming concepts.
a7
This says: "if ID is 6, increase 5"... why 5 and not increase "6"?
copy/paste/edit/fail.
a7
It did not work.
But you could not possibly tested it very well.
Without seeing any more of your code than the below, it is obvious that you have typographical error, or the strangest code ever built:
else if(id == 5)
eepLoc=0;
user=user5++;
else if(id == 6)
eepLoc=840;
user=user5++;  // <----- right here, see what you missed?
else if(id == 7)
eepLoc=1050;
user=user7++;
else if(id == 8)
eepLoc=1260;
user=user8++;
That's one of the many disadvantages to growing your sketch by copy/paste/editing working blocks of code.
a7
Same-same here
This is the code that I got.
I only changed added some comments, change the delays, and modified the code of the LCD in that code
Okay, I'll change that
That made me confused as well, thinking there's a reason behind that mistake or what
else if(id == 10)
eepLoc=1680;
user=user10++;
It's only 10 users in the code that I copy pasted from Fingerprint Based Biometric Attendance System using Arduino - SovanHax
else if(id == 11) //
eepLoc=1890;
user=user11++;
I want it to have 11 users and more (up to 50). Am I doing the right thing? Do I just add 210 to the eepLoc, since the eepLoc started with 210?
You should show the new sketch you have after the changes you made.
You said you posted original unmodified code. did that code have this:
Did that code have those typos?
If not, please post the original unmodified code.
TBH that code is not very good, and it is not a good idea to use it to copy/edit/paste your way to 60 users.
Have you looked into functions and array variables in the context of Arduino programming?
I'll wait. :expressionless:
a7
that's the sketch after the changes that I made
here's the original sketch from the link
	   #include "Adafruit_Fingerprint.h" //fingerprint library header file
LiquidCrystal lcd(8,9,10,11,12,13);
SoftwareSerial fingerPrint(2, 3); //for tx/rx communication between arduino & r305 fingerprint sensor
#include <Wire.h>
RTC_DS3231 rtc;
uint8_t id;
#define forward 16
#define reverse 17
#define match 5
#define indFinger 7
#define buzzer 5
DateTime now;
lcd.begin(16,2);
lcd.clear();
lcd.setCursor(0,1);
Serial.print(i+1);
Serial.print(" ");
int eepIndex=0;
if(i+1<10)
Serial.print('0');
Serial.print(i+1);
Serial.print(" ");
eepIndex=(i*7);
download(eepIndex);
eepIndex=(i*7)+210;
download(eepIndex);
eepIndex=(i*7)+420;
download(eepIndex);
eepIndex=(i*7)+630;
download(eepIndex);
eepIndex=(i*7)+840;
download(eepIndex);
download(eepIndex);
download(eepIndex);
download(eepIndex);
download(eepIndex);
lcd.clear();
lcd.setCursor(0,1);
EEPROM.write(i,0);
lcd.clear();
lcd.clear();
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
EEPROM.write(i,0);
lcd.clear();
lcd.setCursor(0,1);
delay(2000);
lcd.clear();
delay(2000);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("Check Connections");
while (1);
if (! rtc.begin())
lcd.setCursor(0,0);
lcd.setCursor(0,1);
delay(3000);
lcd.clear();
now = rtc.now();
lcd.setCursor(0,0);
lcd.print(':');
lcd.print(':');
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print('/');
lcd.print('/');
lcd.print(" ");
if(result>0)
delay(100);
lcd.clear();
lcd.print("ID:");
lcd.print(result);
lcd.setCursor(0,1);
attendance(result);
lcd.clear();
lcd.setCursor(0,1);
return;
checkKeys();
delay(300);
if(id == 1)
eepLoc=0;
user=user1++;
else if(id == 2)
eepLoc=210;
user=user2++;
else if(id == 3)
eepLoc=420;
user=user3++;
else if(id == 4)
eepLoc=630;
user=user4++;
else if(id == 5)
eepLoc=0;
user=user5++;
else if(id == 6)
eepLoc=840;
user=user5++;
else if(id == 7)
eepLoc=1050;
user=user7++;
else if(id == 8)
eepLoc=1260;
user=user8++;
else if(id == 9)
eepLoc=1470;
user=user9++;
else if(id == 10)
eepLoc=1680;
user=user8++;
eepLoc=840;
user=user5++;
return;
void checkKeys()
lcd.clear();
Enroll();
lcd.clear();
delet();
void Enroll()
int count=1;
lcd.clear();
while(1)
lcd.setCursor(0,1);
lcd.print(count);
count++;
if(count>records)
count=1;
count--;
if(count<1)
count=records;
id=count;
return;
return;
void delet()
int count=1;
lcd.clear();
while(1)
lcd.setCursor(0,1);
lcd.print(count);
count++;
if(count>records)
count=1;
count--;
if(count<1)
count=records;
id=count;
return;
return;
int p = -1;
lcd.clear();
lcd.print(id);
lcd.setCursor(0,1);
delay(2000);
switch (p)
lcd.clear();
lcd.clear();
lcd.clear();
lcd.clear();
default:
lcd.clear();
// OK success!
switch (p) {
lcd.clear();
lcd.clear();
return p;
lcd.clear();
return p;
lcd.clear();
return p;
lcd.clear();
return p;
default:
lcd.clear();
return p;
lcd.clear();
delay(2000);
p = 0;
p = -1;
lcd.clear();
lcd.setCursor(0,1);
switch (p) {
Serial.print(".");
default:
return;
// OK success!
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
return p;
return p;
return p;
lcd.clear();
delay(2000);
return p;
return p;
return p;
else {
return p;
return -1;
return -1;
lcd.clear();
lcd.setCursor(0,1);
delay(2000);
return -1;
// found a match!
uint8_t p = -1;
lcd.clear();
lcd.clear();
lcd.setCursor(0,1);
lcd.clear();
lcd.setCursor(0,1);
delay(2000);
return p;
Serial.print('0');
Serial.print(':');
Serial.print('0');
Serial.print(':');
Serial.print('0');
Serial.print('0');
Serial.print('/');
Serial.print('0');
Serial.print('/');
Serial.print(" ");
still going to
I made that actually but eventually turned it into comments since I'm not sure about it
I appreciate you for letting me know about it. I'm willing to learn about this
I only have a moment here, but a tip,is to start using the IDE Autoformat tool.
It will,put your code into into a standard format, with nice indentation and so forth that will make it pretty and much easier to read.
Try it now. You could edit the last post where you placed the original original code (THX!) after applying the Autoformat tool to it in the IDE, then just paste right over the code you posted, leaving the tick marks that make it appear as code I damaged.
a7
