How do I differentiate between Initialization and Declaration?
Hello all,
I have written this above setup.
int life = 3
Does this tell the arduino that pin 3 is now called life, or does it give the integer life an initial value of 3?
If someone could tell me how to do both things, that would be most helpful.
I would also like to know how to set an integer (that has been happily counting) back to zero before the loop starts again.
Thank you for your time!
Joe.
It tells the compiler you want a 16 bit global variable called "life", and you want its value to be three before setup runs.
Nothing at all to do with pins, unless YOU want it to be.
Happy or sad, set it back to zero when you've finished with it.
Holy pants that was fast AWOL. Thanks for the reply. Could you tell me how I would assign 'life' to a pin?
AWOL:
Like this?
int life == 0;
You can't assign a sixteen bit variable to a one bit pin, but you can use it as the name of the pin, e.g.
int life = 3;
pinMode (life, OUTPUT);
but there's nothing which binds the variable to pin 3.
No, not like that, that's creating a new "life" (and we all know what trouble that can land you in).
Lose the "int" and one of the "="
AWOL:
like this:
x = 0;
Getting there!
So if I was to write
digitalWrite(life, HIGH);
How would it know which pin to make high? I have a feeling I have massively misunderstood something fundamental about arduino (or C)
It takes the value in the variable "life" and uses that to address the pin.
Haddonjw:
Well, about high level languages you have... a initialization assigns a symbol to a value. "life" is the symbol, 3 is the value. But a declaration may not initialize the value by default. You can just declare "life" and assign a value later. Assignment is a mechanism for changing the value associated with a symbol. A reference to the symbol produces the value.
Behind the scenes, a value is stored in a memory location. You don't have to sweat that too much unless you're using pointers. But a declaration with no initializer reserves a memory location for future values to be saved.
It's more a lot more complicated than this, but the short version is that the magic is essentially based on giving names to memory locations.
You assign the pin numbers at the top of your sketch.
byte life = 13; // can be any pin - use 13 as that's the onboard LED
void setup(){
void loop(){
// make life pin go High & Low about every 1/2 second
digitalWrite (life, HIGH);
delay (500);
digitalWrite (life, LOW);
int life = 3;
life - 2;
digitalWrite(life, LOW);
life = 0
Would that turn pin 3 on, then pin 1 and then reset life to 0?
I really do appreciate your time, you have all given me spectacularly useful info.
No, because
life - 2;
doesn't do anything useful (though the compiler won't complain).
life = life - 2;
is one version of what you want.
AWOL and Delta_G, I think you may have cracked it! I am writing a code for a simple 2 team IR laser tag game. This is the life counter.
I will quickly go stuff in these changes and let you know.
Thanks so very much.
The program that CrossRoads gave you is similar to the Blink program that comes with the Arduino IDE. You can load that program with the menu sequence:
File --> Examples --> 01.Basics --> Blink
That program looks like:
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
As CrossRoads pointed out, pin 13 is the pin that has the onboard LED tied to it. Most C programmers, however, don't like "magic numbers" in their programs, so the will define a variable and use that instead. So you could modify the Blink program as:
int ONBOARD_LED = 13;
  pinMode(ONBOARD_LED , OUTPUT);
  digitalWrite(ONBOARD_LED , HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(ONBOARD_LED , LOW);    // turn the LED off by making the voltage LOW
In this case, ONBOARD_LED is a variable that is initialized to a value of 13. Functionally, the two programs are identical, but the second flavor is easier to read because the value 13 is now assigned to a variable with a name that makes more sense in context. While not required, because the onboard LED pin doesn't change for most Arduino boards, it's a constant pin number from board-to-board. Therefore, most C programmers would use uppercase letters for the variable name so the person reading the code knows its a variable that shouldn't be changed. If you want to make sure the variable doesn't change, you could define it as:
const int ONBOARD_LED = 13;
With this definition, any attempt to change its value in the program will draw an error message from the compiler.
No, one would typically use an array for that.
byte pinsArray[] = {3,1,0,}; // be careful using 1, 0 as those are also the Serial port pins
// pinsArray[0] = 3, pinsArray[1] = 1, pinsArray[2] = 0
byte x;  // variable to use in a loop
void setup(){
for (x = 0; x<3; x=x+1){ // count from 0,1,2
pinMode (pinsArray[x],  OUTPUT); // set pin 3, then 1, then 0 as outputs
void loop(){
digitalWrite (pinsArray[x],  HIGH); // set pin 3, then 1, then 0 HIGH
delay(100); // 100mS pause
digitalWrite (pinsArray[x],  LOW); // set pin 3, then 1, then 0 LOW
delay (100);
} // end of loop
Great info thanks econjack. Crossroads, the array thing made me want to run away to my mummy... riding a pink vespa...
I put in my new knowledge about changing variables... it seems to sort of do it...
Here's the code. I have some kind of craziness going on where it will lose 1 life on the first hit but then two or three on the next successive one's
#define RCVR 2    //IR RCVR Signal pin
#define RPOS 5    //IR RCVR positive pin
#define EMIT 3    //IR LED pin
#define TS  13    //Team Switch Common
#define TA 12     // Team Switch is A
#define TB 7      // Team Switch is B
#define TRIG 4    //Trigger pin
#define lONE 9    //One life left
#define lTWO 10   //Two lives left
#define lTHREE 11 //Three lives left
int life;     // Life Counter, Get three on reset
int pLen;         // To be used to measure Pulse Length
int lenCount;     //Counts the number of incoming pulses
int aHit;         //Gives number of A Pulses that equals a hit
int bHit;         //Gives number of B Pulses that equals a hit
int sigGEN;       //Makes the A and B Signals
    pinMode (RCVR, INPUT);
    pinMode (RPOS, OUTPUT);
    pinMode (EMIT, OUTPUT);
    pinMode (TS, OUTPUT);
    pinMode (TA, INPUT);
    pinMode (TB, INPUT);
    pinMode (TRIG, INPUT);
    pinMode (lONE, OUTPUT);
    pinMode (lTWO, OUTPUT);
    pinMode (lTHREE, OUTPUT);
    if(life == 0)             //There are 0 lives at start
      {life++;                //add first
      life++;                 //add second
      life++;                 //add third
    Serial.begin(9600); // open a serial connection to your computer
  if(life == 3)
     {digitalWrite(lONE, HIGH);                                        //
      digitalWrite(lTWO, HIGH);
      digitalWrite(lTHREE, HIGH);
   if(life == 2)
      digitalWrite(lTHREE, LOW);
   if(life == 1)
      digitalWrite(lTWO, LOW);
   if(life == 0)
     {digitalWrite(lONE, LOW);                                        //
     if(life < 0)
  digitalWrite(RPOS, HIGH);                                        //Turn on the Receiver
          if (digitalRead(RCVR)== 0)                               // If the RCVR pin has started to receive
              {for (int lenCount=0; lenCount <8; lenCount++)    // Do the following 10x
                    {pLen = pulseIn(RCVR, LOW);                    //Measure the length of the received pulse
                     if (pLen > 8000)                              //If it is more than 8000
                         {if(pLen < 12000)                         //and less than 12000
                             {aHit++;                              //Count one pulse for A
                      if (pLen > 27000)                           //If it is more than 8000
                         {if(pLen < 31000)                        //and less than 12000
                             { bHit++;                            //Count one pulse for B
                    }                                             //Move on if count gets to <8
                                Serial.print(life);
                                if(aHit > 5)                      //If there are more than 5 A pulses
                                  {digitalWrite(TS,HIGH);         //Make the Team Switch live
                                      if(digitalRead(TA) == HIGH) //If Team Switch is A (Friendly Fire)
                                          {life-=2;                //Lose 2 lives
                                      if(digitalRead(TB) == HIGH) //If Team Switch is B (Enemy Fire)
                                          {life--;                //Lose 1 life
                                if(bHit > 5)                      //If there are more than 5 A pulses
                                      if(digitalRead(TB) == HIGH) //If Team Switch is B (Friendly Fire)
                                      if(digitalRead(TA) == HIGH) //If Team Switch is A (Enemy Fire)
                                    Serial.print(life);
                                aHit = 0;                        //Reset aHit
                                bHit = 0;                        //Reset bHit
Here's the serial after a few shots.. 3 being the lives before, 2 after.
32
20
0-3
-3-6
-6-9
-9-12
-12-14
-14-16
-16-19
-19-21
-21-24
I am hoping the serial to run
32
21
10
0-1
-1-2
etc
Course, I never claimed to be a C programmer, I'm just a hardware designer who plays at being a programmer here 8) So my examples may not follow all the software conventions ...
Wow.. just noticed it's 3:47 here. Off to sleep, I'll be back in about 2 hrs when my kids kick me!!
Thanks for your time and help everyone - marvellous.
@CrossRoads: That was not meant as a comment on your code. Instead, it was to shed some light on code the OP might read where some ID's are all uppercase letters and he wondered why. Indeed, it's interesting that he then went off and used #define's to get rid of the magic numbers. (I actually prefer #define since it creates a typeless substitution. I feel differently when there's a symbolic debugger available.)
