How do i fix this script?
Hello. I was trying to make a vr controlller using arduino nano. The problem is in my script(script is below).
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class using DMP (MotionApps v2.0)
// 6/21/2012 by Jeff Rowberg <jeff@rowberg.net>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
//      2016-04-18 - Eliminated a potential infinite loop
//      2013-05-08 - added seamless Fastwire support
//                 - added note about gyro calibration
//      2012-06-21 - added note about Arduino 1.0.1 + Leonardo compatibility error
//      2012-06-20 - improved FIFO overflow handling and simplified read process
//      2012-06-19 - completely rearranged DMP initialization code and simplification
//      2012-06-13 - pull gyro and accel data from FIFO packet instead of reading directly
//      2012-06-09 - fix broken FIFO read sequence and change interrupt detection to RISING
//      2012-06-05 - add gravity-compensated initial reference frame acceleration output
//                 - add 3D math helper file to DMP6 example sketch
//                 - add Euler output and Yaw/Pitch/Roll output formats
//      2012-06-04 - remove accel offset clearing for better results (thanks Sungon Lee)
//      2012-06-01 - fixed gyro sensitivity to be 2000 deg/sec instead of 250
//      2012-05-30 - basic DMP initialization working
I2Cdev device library code is placed under the MIT license
Copyright (c) 2012 Jeff Rowberg
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
 #ifndef BUFFER_LENGTH
 // band-aid fix for platforms without Wire-defined BUFFER_LENGTH (removed from some official implementations)
 #define BUFFER_LENGTH 32
 #endif
 #ifndef _BV
#define _BV(n) (1<<(n))
#endif
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
//MPU6050 mpu(0x69); // <-- use for AD0 high
   NOTE: In addition to connection 3.3v, GND, SDA, and SCL, this sketch
   depends on the MPU-6050's INT pin being connected to the Arduino's
   external interrupt #0 pin. On the Arduino Uno and Mega 2560, this is
   digital I/O pin 2.
   NOTE: Arduino v1.0.1 with the Leonardo board generates a compile error
   when using Serial.write(buf, len). The Teapot output uses this method.
   The solution requires a modification to the Arduino USBAPI.h file, which
   is fortunately simple, but annoying. This will be fixed in the next IDE
   release. For more info, see these links:
   http://arduino.cc/forum/index.php/topic,109987.0.html
   http://code.google.com/p/arduino/issues/detail?id=958
// uncomment "OUTPUT_READABLE_QUATERNION" if you want to see the actual
// quaternion components in a [w, x, y, z] format (not best for parsing
// on a remote host such as Processing or something though)
//#define OUTPUT_READABLE_QUATERNION
// uncomment "OUTPUT_READABLE_EULER" if you want to see Euler angles
// (in degrees) calculated from the quaternions coming from the FIFO.
// Note that Euler angles suffer from gimbal lock (for more info, see
// http://en.wikipedia.org/wiki/Gimbal_lock)
//#define OUTPUT_READABLE_EULER
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
// pitch/roll angles (in degrees) calculated from the quaternions coming
// from the FIFO. Note this also requires gravity vector calculations.
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
#define OUTPUT_READABLE_YAWPITCHROLL
// uncomment "OUTPUT_READABLE_REALACCEL" if you want to see acceleration
// components with gravity removed. This acceleration reference frame is
// not compensated for orientation, so +X is always +X according to the
// sensor, just without the effects of gravity. If you want acceleration
// compensated for orientation, us OUTPUT_READABLE_WORLDACCEL instead.
//#define OUTPUT_READABLE_REALACCEL
// uncomment "OUTPUT_READABLE_WORLDACCEL" if you want to see acceleration
// components with gravity removed and adjusted for the world frame of
// reference (yaw is relative to initial orientation, since no magnetometer
// is present in this case). Could be quite handy in some cases.
//#define OUTPUT_READABLE_WORLDACCEL
// uncomment "OUTPUT_TEAPOT" if you want output that matches the
// format used for the InvenSense teapot demo
//#define OUTPUT_TEAPOT
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
// packet structure for InvenSense teapot demo
uint8_t teapotPacket[14] = { '$', 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
// ===               INTERRUPT DETECTION ROUTINE                ===
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
    mpuInterrupt = true;
//Controller TrueOpenVR
#define GRIP_BTN  0x0001
#define THUMB_BTN 0x0002
#define A_BTN   0x0004
#define B_BTN   0x0008
#define MENU_BTN  0x0010
#define SYS_BTN   0x0020
//Digital pins number / ������ �������� �����
const byte TriggerBtnPin = 3;
const byte GripBtnPin = 4;
const byte ThumbStickBtnPin = 5;
const byte MenuBtnPin = 6;
const byte SystemBtnPin = 7;
//Button for emulating stick movement
const byte UpStickPin = 7;
const byte LeftStickPin = 8;
const byte RightStickPin = 9;
const byte DownStickPin = 10;
float ctrl[12];
// ===                      INITIAL SETUP                       ===
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
        Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    // initialize serial communication
    // (115200 chosen because it is required for Teapot Demo output, but it's
    // really up to you depending on your project)
    //Setup pins
    pinMode(TriggerBtnPin, INPUT_PULLUP);
    pinMode(GripBtnPin, INPUT_PULLUP);
    pinMode(ThumbStickBtnPin, INPUT_PULLUP);
    pinMode(SystemBtnPin, INPUT_PULLUP);
    pinMode(MenuBtnPin, INPUT_PULLUP);
    pinMode(UpStickPin, INPUT_PULLUP);
    pinMode(LeftStickPin, INPUT_PULLUP);
    pinMode(RightStickPin, INPUT_PULLUP);
    pinMode(DownStickPin, INPUT_PULLUP);
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
    // NOTE: 8MHz or slower host processors, like the Teensy @ 3.3V or Arduino
    // Pro Mini running at 3.3V, cannot handle this baud rate reliably due to
    // the baud timing being too misaligned with processor ticks. You must use
    // 38400 or slower in these cases, or use some kind of external separate
    // crystal solution for the UART timer.
    // initialize device
    //Serial.println(F("Initializing I2C devices..."));
    mpu.initialize();
    pinMode(INTERRUPT_PIN, INPUT);
    // verify connection
    //Serial.println(F("Testing device connections..."));
    //Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
    // wait for ready
    //Serial.println(F("\nSend any character to begin DMP programming and demo: "));
    //while (Serial.available() && Serial.read()); // empty buffer
    //while (!Serial.available());                 // wait for data
    //while (Serial.available() && Serial.read()); // empty buffer again
    // load and configure the DMP
    //Serial.println(F("Initializing DMP..."));
    devStatus = mpu.dmpInitialize();
    // calibration
    // supply your own gyro offsets here, scaled for min sensitivity
    mpu.setXGyroOffset(164);
    mpu.setYGyroOffset(-151);
    mpu.setZGyroOffset(-16);
    mpu.setXAccelOffset(-2174);
    mpu.setYAccelOffset(-162);
    mpu.setZAccelOffset(785);
    // make sure it worked (returns 0 if so)
    if (devStatus == 0) {
        // turn on the DMP, now that it's ready
        //Serial.println(F("Enabling DMP..."));
        mpu.setDMPEnabled(true);
        // enable Arduino interrupt detection
        //Serial.print(F("Enabling interrupt detection (Arduino external interrupt "));
        //Serial.print(digitalPinToInterrupt(INTERRUPT_PIN));
        //Serial.println(F(")..."));
        attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
        mpuIntStatus = mpu.getIntStatus();
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
        //Serial.println(F("DMP ready! Waiting for first interrupt..."));
        dmpReady = true;
        // get expected DMP packet size for later comparison
        packetSize = mpu.dmpGetFIFOPacketSize();
        // ERROR!
        // 1 = initial memory load failed
        // 2 = DMP configuration updates failed
        // (if it's going to break, usually the code will be 1)
        //Serial.print(F("DMP Initialization failed (code "));
        //Serial.print(devStatus);
        //Serial.println(F(")"));
    // configure LED for output
    pinMode(LED_PIN, OUTPUT);
// ===                    MAIN PROGRAM LOOP                     ===
    // if programming failed, don't try to do anything
    if (!dmpReady) return;
    // wait for MPU interrupt or extra packet(s) available
    while (!mpuInterrupt && fifoCount < packetSize) {
        if (mpuInterrupt && fifoCount < packetSize) {
          // try to get out of the infinite loop
          fifoCount = mpu.getFIFOCount();
        // other program behavior stuff here
        // if you are really paranoid you can frequently test in between other
        // stuff to see if mpuInterrupt is true, and if so, "break;" from the
        // while() loop to immediately process the MPU data
    // reset interrupt flag and get INT_STATUS byte
    // get current FIFO count
    // check for overflow (this should never happen unless our code is too inefficient)
    if ((mpuIntStatus & _BV(MPU6050_INTERRUPT_FIFO_OFLOW_BIT)) || fifoCount >= 1024) {
        // reset so we can continue cleanly
        mpu.resetFIFO();
        //Serial.println(F("FIFO overflow!"));
    // otherwise, check for DMP data ready interrupt (this should happen frequently)
    } else if (mpuIntStatus & _BV(MPU6050_INTERRUPT_DMP_INT_BIT)) {
        // wait for correct available data length, should be a VERY short wait
        while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
        // read a packet from FIFO
        mpu.getFIFOBytes(fifoBuffer, packetSize);
        // track FIFO count here in case there is > 1 packet available
        // (this lets us immediately read more without waiting for an interrupt)
        fifoCount -= packetSize;
        #ifdef OUTPUT_READABLE_QUATERNION
            // display quaternion values in easy matrix form: w x y z
            mpu.dmpGetQuaternion(&q, fifoBuffer);
            Serial.print("quat\t");
            Serial.print(q.w);
            Serial.print("\t");
            Serial.print(q.x);
            Serial.print("\t");
            Serial.print(q.y);
            Serial.print("\t");
            Serial.println(q.z);
        #endif
        #ifdef OUTPUT_READABLE_EULER
            // display Euler angles in degrees
            mpu.dmpGetEuler(euler, &q);
            Serial.print("euler\t");
            Serial.print(euler[0] * 180/M_PI);
            Serial.print("\t");
            Serial.print(euler[1] * 180/M_PI);
            Serial.print("\t");
            Serial.println(euler[2] * 180/M_PI);
        #endif
        #ifdef OUTPUT_READABLE_YAWPITCHROLL
            mpu.dmpGetGravity(&gravity, &q);
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
            //Serial.print("ypr\t");
            //Serial.print(ypr[0] * 180/M_PI);
            //Serial.print("\t");
            //Serial.print(ypr[1] * 180/M_PI);
            //Serial.println(ypr[2] * 180/M_PI);
      //Position with bones rotation (two gyroscope, read more https://github.com/TrueOpenVR/TrueOpenVR-DIY)
            //Set pos for testing
            ctrl[0] = 0; ////x -0.1
            ctrl[1] = 0;  //y -0.3
            ctrl[2] = 0; //y -0.1
            //If X,Y,Z positions are zeros, then the position is calculated based on IMUs
            //���� X,Y,Z ������� �� ����� ������ ������� �������������� �� ������ IMUs
            ctrl[3] = ypr[0] * 180/M_PI;
            ctrl[4] = ypr[2] * 180/M_PI * -1;
            ctrl[5] = ypr[1] * 180/M_PI;
            //Position shoulder
            ctrl[6] = 0;
            ctrl[7] = 0;
            //Buttons
            ctrl[8] = 0; //Buttons
            ctrl[9] = 0; //Trigger
            ctrl[10] = 0; //ThumbX
            ctrl[11] = 0; //ThumbY
            //Checking press buttons
            int CtrlButtons = 0;
            if (digitalRead(GripBtnPin) == LOW)
              CtrlButtons |= GRIP_BTN;
            if (digitalRead(ThumbStickBtnPin) == LOW)
              CtrlButtons |= THUMB_BTN;
            if (digitalRead(MenuBtnPin) == LOW)
              CtrlButtons |= MENU_BTN;
            if (digitalRead(SystemBtnPin) == LOW)
              CtrlButtons |= SYS_BTN;
            //Buttons
             ctrl[8] = CtrlButtons;
            //Trigger
            if (digitalRead(TriggerBtnPin) == LOW)
              ctrl[9] = 1;
            //Stick emulation
            if (digitalRead(UpStickPin) == LOW)
              ctrl[11] = 1; //Up
            if (digitalRead(LeftStickPin) == LOW)
              ctrl[10] = -1; //Left
            if (digitalRead(RightStickPin) == LOW)
              ctrl[10] = 1; //Right
            if (digitalRead(DownStickPin) == LOW)
              ctrl[11] = -1; //Down
            //Output binary
            Serial.write((byte*)&ctrl, sizeof(ctrl));
        #endif
        #ifdef OUTPUT_READABLE_REALACCEL
            // display real acceleration, adjusted to remove gravity
            mpu.dmpGetAccel(&aa, fifoBuffer);
            mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
            Serial.print("areal\t");
            Serial.print(aaReal.x);
            Serial.print("\t");
            Serial.print(aaReal.y);
            Serial.print("\t");
            Serial.println(aaReal.z);
        #endif
        #ifdef OUTPUT_READABLE_WORLDACCEL
            // display initial world-frame acceleration, adjusted to remove gravity
            // and rotated based on known orientation from quaternion
            mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
            Serial.print("aworld\t");
            Serial.print(aaWorld.x);
            Serial.print("\t");
            Serial.print(aaWorld.y);
            Serial.print("\t");
            Serial.println(aaWorld.z);
        #endif
        #ifdef OUTPUT_TEAPOT
            // display quaternion values in InvenSense Teapot demo format:
            teapotPacket[2] = fifoBuffer[0];
            teapotPacket[3] = fifoBuffer[1];
            teapotPacket[4] = fifoBuffer[4];
            teapotPacket[5] = fifoBuffer[5];
            teapotPacket[6] = fifoBuffer[8];
            teapotPacket[7] = fifoBuffer[9];
            teapotPacket[8] = fifoBuffer[12];
            teapotPacket[9] = fifoBuffer[13];
            Serial.write(teapotPacket, 14);
            teapotPacket[11]++; // packetCount, loops at 0xFF on purpose
        #endif
        // blink LED to indicate activity
        //blinkState = !blinkState;
        //digitalWrite(LED_PIN, blinkState);
but when i compile this script, my arduino ide shows me this error:
In file included from c:\users\adamg\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\io.h:99:0,
                 from c:\users\adamg\appdata\local\arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7\avr\include\avr\pgmspace.h:90,
                 from C:\Users\adamg\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/Arduino.h:28,
                 from C:\Users\adamg\AppData\Local\Temp\arduino-sketch-C097815EAAB45D93716BB6E7295E5018\sketch\sketch_dec23a.ino.cpp:1:
C:\Users\adamg\AppData\Local\Temp\.arduinoIDE-unsaved20221123-1160-fim22o.ddgfr\sketch_dec23a\sketch_dec23a.ino: In function 'void loop()':
C:\Users\adamg\AppData\Local\Temp\.arduinoIDE-unsaved20221123-1160-fim22o.ddgfr\sketch_dec23a\sketch_dec23a.ino:328:29: error: 'MPU6050_INTERRUPT_FIFO_OFLOW_BIT' was not declared in this scope
C:\Users\adamg\AppData\Local\Temp\.arduinoIDE-unsaved20221123-1160-fim22o.ddgfr\sketch_dec23a\sketch_dec23a.ino:328:29: note: suggested alternative:
In file included from C:\Users\adamg\OneDrive\Dokumenty\Arduino\libraries\MPU6050-0.6.0\src/MPU6050_6Axis_MotionApps20.h:44:0,
                 from C:\Users\adamg\AppData\Local\Temp\.arduinoIDE-unsaved20221123-1160-fim22o.ddgfr\sketch_dec23a\sketch_dec23a.ino:56:
C:\Users\adamg\OneDrive\Dokumenty\Arduino\libraries\MPU6050-0.6.0\src/MPU6050.h:442:5: note:   'MPU6050_INTERRUPT_FIFO_OFLOW_BIT'
     MPU6050_INTERRUPT_FIFO_OFLOW_BIT,
C:\Users\adamg\AppData\Local\Temp\.arduinoIDE-unsaved20221123-1160-fim22o.ddgfr\sketch_dec23a\sketch_dec23a.ino:335:35: error: 'MPU6050_INTERRUPT_DMP_INT_BIT' was not declared in this scope
C:\Users\adamg\AppData\Local\Temp\.arduinoIDE-unsaved20221123-1160-fim22o.ddgfr\sketch_dec23a\sketch_dec23a.ino:335:35: note: suggested alternative:
C:\Users\adamg\OneDrive\Dokumenty\Arduino\libraries\MPU6050-0.6.0\src/MPU6050.h:439:5: note:   'MPU6050_INTERRUPT_DMP_INT_BIT'
     MPU6050_INTERRUPT_DMP_INT_BIT,
exit status 1
Compilation error: 'MPU6050_INTERRUPT_FIFO_OFLOW_BIT' was not declared in this scope
I dont know how to fix it.
did you meet this requirement?
no, thank you, i will check :slight_smile:
this still does not work
what did you install?
➜ this is it
i2cdevlib/Arduino/MPU6050 at 9b2b3c151697abfbdf75e4cea85d1c55cd52b9e6 · jrowberg/i2cdevlib · GitHub
is there a new error?
i downoloaded 12cdevlib, but arduino ide shows me error, but MPU6050-0.60.0 works fine
downoloaded from here: MPU6050 - Arduino Libraries
now i have another problem. i reinstalled my libraries and now i have this error `C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:61:0: error: unterminated #if
exit status 1
Compilation error: unterminated #if`
i have a problem here too: ``` In file included from C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:49:0:
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:46:56: error: expected class-name before '{' token
class MPU6050_6Axis_MotionApps20 : public MPU6050_Base {
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:81:29: error: 'VectorInt16' has not been declared
uint8_t dmpGetAccel(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:81:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetAccel(int*, const uint8_t*)' cannot be overloaded
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:80:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetAccel(int16_t*, const uint8_t*)'
uint8_t dmpGetAccel(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:84:34: error: 'Quaternion' has not been declared
uint8_t dmpGetQuaternion(Quaternion q, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:84:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetQuaternion(int*, const uint8_t*)' cannot be overloaded
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:83:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetQuaternion(int16_t*, const uint8_t*)'
uint8_t dmpGetQuaternion(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:87:39: error: 'Quaternion' has not been declared
uint8_t dmpGet6AxisQuaternion(Quaternion q, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:87:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGet6AxisQuaternion(int*, const uint8_t*)' cannot be overloaded
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:86:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGet6AxisQuaternion(int16_t*, const uint8_t*)'
uint8_t dmpGet6AxisQuaternion(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:90:42: error: 'Quaternion' has not been declared
uint8_t dmpGetRelativeQuaternion(Quaternion data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:90:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetRelativeQuaternion(int*, const uint8_t*)' cannot be overloaded
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:89:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetRelativeQuaternion(int16_t*, const uint8_t*)'
uint8_t dmpGetRelativeQuaternion(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:93:28: error: 'VectorInt16' has not been declared
uint8_t dmpGetGyro(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:93:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetGyro(int*, const uint8_t*)' cannot be overloaded
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:92:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetGyro(int16_t*, const uint8_t*)'
uint8_t dmpGetGyro(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:97:35: error: 'VectorInt16' has not been declared
uint8_t dmpGetLinearAccel(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:97:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetLinearAccel(int*, const uint8_t*)' cannot be overloaded
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:96:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetLinearAccel(int16_t*, const uint8_t*)'
uint8_t dmpGetLinearAccel(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:98:35: error: 'VectorInt16' has not been declared
uint8_t dmpGetLinearAccel(VectorInt16 *v, VectorInt16 *vRaw, VectorFloat *gravity);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:98:51: error: 'VectorInt16' has not been declared
uint8_t dmpGetLinearAccel(VectorInt16 *v, VectorInt16 vRaw, VectorFloat gravity);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:98:70: error: 'VectorFloat' has not been declared
uint8_t dmpGetLinearAccel(VectorInt16 v, VectorInt16 vRaw, VectorFloat gravity);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:101:42: error: 'VectorInt16' has not been declared
uint8_t dmpGetLinearAccelInWorld(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:101:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetLinearAccelInWorld(int
, const uint8_t
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:100:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetLinearAccelInWorld(int16_t
, const uint8_t
uint8_t dmpGetLinearAccelInWorld(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:102:42: error: 'VectorInt16' has not been declared
uint8_t dmpGetLinearAccelInWorld(VectorInt16 v, VectorInt16 vReal, Quaternion q);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:102:58: error: 'VectorInt16' has not been declared
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:102:78: error: 'Quaternion' has not been declared
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:105:42: error: 'VectorInt16' has not been declared
uint8_t dmpGetGyroAndAccelSensor(VectorInt16 g, VectorInt16 a, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:105:58: error: 'VectorInt16' has not been declared
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:108:34: error: 'VectorInt16' has not been declared
uint8_t dmpGetGyroSensor(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:108:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetGyroSensor(int
, const uint8_t
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:107:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetGyroSensor(int16_t
, const uint8_t
uint8_t dmpGetGyroSensor(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:113:31: error: 'VectorInt16' has not been declared
uint8_t dmpGetGravity(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:113:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetGravity(int
, const uint8_t
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:112:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetGravity(int16_t
, const uint8_t
uint8_t dmpGetGravity(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:114:31: error: 'VectorFloat' has not been declared
uint8_t dmpGetGravity(VectorFloat v, Quaternion q);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:114:47: error: 'Quaternion' has not been declared
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:117:40: error: 'VectorInt16' has not been declared
uint8_t dmpGetUnquantizedAccel(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:117:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetUnquantizedAccel(int
, const uint8_t
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:116:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetUnquantizedAccel(int16_t
, const uint8_t
uint8_t dmpGetUnquantizedAccel(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:120:38: error: 'VectorInt16' has not been declared
uint8_t dmpGetQuantizedAccel(VectorInt16 v, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:120:17: error: 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetQuantizedAccel(int
, const uint8_t
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:119:17: error: with 'uint8_t MPU6050_6Axis_MotionApps20::dmpGetQuantizedAccel(int16_t
, const uint8_t
uint8_t dmpGetQuantizedAccel(int16_t data, const uint8_t packet=0);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:124:42: error: 'Quaternion' has not been declared
uint8_t dmpGetEuler(float *data, Quaternion *q);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:125:49: error: 'Quaternion' has not been declared
uint8_t dmpGetYawPitchRoll(float *data, Quaternion *q, VectorFloat *gravity);
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:125:64: error: 'VectorFloat' has not been declared
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:48:52: error: 'MPU6050_DEFAULT_ADDRESS' was not declared in this scope
MPU6050_6Axis_MotionApps20(uint8_t address=MPU6050_DEFAULT_ADDRESS, void wireObj=0) : MPU6050_Base(address, wireObj) { }
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:48:52: note: suggested alternative:
In file included from C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:44:0,
C:\Users\adamg\OneDrive\Dokumenty\Arduino\libraries\MPU6050-0.6.0\src/MPU6050.h:73:21: note: 'MPU6050_IMU::MPU6050_DEFAULT_ADDRESS'
constexpr uint8_t MPU6050_DEFAULT_ADDRESS = MPU6050_ADDRESS_AD0_LOW;
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h: In constructor 'MPU6050_6Axis_MotionApps20::MPU6050_6Axis_MotionApps20(uint8_t, void
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:48:96: error: class 'MPU6050_6Axis_MotionApps20' does not have any field named 'MPU6050_Base'
MPU6050_6Axis_MotionApps20(uint8_t address=MPU6050_DEFAULT_ADDRESS, void *wireObj=0) : MPU6050_Base(address, wireObj) { }
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h: At global scope:
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\MPU6050_6Axis_MotionApps20.h:151:36: error: conflicting declaration 'typedef class MPU6050_6Axis_MotionApps20 MPU6050'
typedef MPU6050_6Axis_MotionApps20 MPU6050;
C:\Users\adamg\OneDrive\Dokumenty\Arduino\libraries\MPU6050-0.6.0\src/MPU6050.h:576:7: note: previous declaration as 'class MPU6050'
class MPU6050 {
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:135:1: error: 'Quaternion' does not name a type; did you mean 'union'?
union
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:136:1: error: 'VectorInt16' does not name a type
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:137:1: error: 'VectorInt16' does not name a type
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:138:1: error: 'VectorInt16' does not name a type
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:139:1: error: 'VectorFloat' does not name a type
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino: In function 'void setup()':
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:241:21: error: 'class MPU6050' has no member named 'dmpInitialize'; did you mean 'initialize'?
initialize
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:270:26: error: 'class MPU6050' has no member named 'dmpGetFIFOPacketSize'
from C:\Users\adamg\AppData\Local\Temp\arduino-sketch-B9D82F698C8464C7DF0254CDD58A54A8\sketch\sketch_dec23a.ino.cpp:1:
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino: In function 'void loop()':
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:321:29: error: 'MPU6050_INTERRUPT_FIFO_OFLOW_BIT' was not declared in this scope
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:321:29: note: suggested alternative:
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:328:35: error: 'MPU6050_INTERRUPT_DMP_INT_BIT' was not declared in this scope
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:328:35: note: suggested alternative:
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:366:17: error: 'class MPU6050' has no member named 'dmpGetQuaternion'
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:366:35: error: 'q' was not declared in this scope
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:366:35: note: suggested alternative: 'sq'
sq
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:367:17: error: 'class MPU6050' has no member named 'dmpGetGravity'
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:367:32: error: 'gravity' was not declared in this scope
C:\Users\adamg\OneDrive\Pulpit\ArduinoaTrueOpenVR\sketch_dec23a\sketch_dec23a.ino:368:17: error: 'class MPU6050' has no member named 'dmpGetYawPitchRoll'
exit status 1
Compilation error: expected class-name before '{' token ```
you downloaded
https://github.com/ElectronicCats/mpu6050
but you need https://github.com/jrowberg/i2cdevlib/tree/9b2b3c151697abfbdf75e4cea85d1c55cd52b9e6/Arduino/MPU6050
they are not the same libraries
