Background: I am working on a electric brewing project using an Arduino Uno R3, two DS18b20 digital temp sensors and Processing IDE as a GUI. I am using the sensors to monitor and control two separate heating elements on SSRs for various steps in beer brewing. I have successfully used the following Arduino and Processing code to send serial data to Processing to generate a dumb temp output GUI showing two separate temps (ACTUAL1,2), relay set points (SETPOINT1,2) and relay states (HEATPIN1,2).
Problem: The control knob generated with the controlP5 library is in the Processing sketch as you will see below but I am asking for help getting it to communicate back to Arduino. I may be going about this all wrong dataflow wise: Arduino to serial to Processing...back to serial? back to Arduino? I tried to scrap most of the Arduino code and use Firmata to Arduino alone but I still need to code in the Dallas sensors into Arduino. Any suggestions would be greatly appreciated, very new to coding. I have the brewing process, hardware and wiring down but lack experience with code. Thank you in advance.
Arduino Code:
//#include <Boards.h>
//#include <Firmata.h>
#include <OneWire.h>
#include <DallasTemperature.h>
int ACTUAL1;
int ACTUAL2;
int SETPOINT1 = 145;
int SETPOINT2 = 150;
int HEATPIN1 = 13;
int HEATPIN2 = 12;
#define ONE_WIRE_BUS 3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress Probe1 = { 0x28, 0xFF, 0x14, 0x23, 0x16, 0x15, 0x03, 0xB9 };
DeviceAddress Probe2 = { 0x28, 0xFF, 0xBA, 0x0D, 0x16, 0x15, 0x03, 0x4D };
void setup(void)
pinMode(HEATPIN1, OUTPUT);
pinMode(HEATPIN2, OUTPUT);
sensors.begin();
sensors.setResolution(Probe1, 10);
sensors.setResolution(Probe2, 10);
void printTemperature(DeviceAddress deviceAddress)
float TempC = sensors.getTempC(deviceAddress);
if (TempC == -127.00) {
Serial.print("Error getting temperature");
ACTUAL1 = (DallasTemperature::toFahrenheit(TempC));
ACTUAL2 = (DallasTemperature::toFahrenheit(TempC));
Serial.print(ACTUAL1);
//Serial.print(ACTUAL2);
void loop(void)
delay(2000);
sensors.requestTemperatures();
//Serial.read();
//SETPOINT1 = Serial.parseInt();
printTemperature(Probe1);
if (ACTUAL1 < 100) {
Serial.print(" ");
Serial.print(",");
Serial.print(SETPOINT1);
if (SETPOINT1 < 100) {
Serial.print(" ");
if (ACTUAL1 >= SETPOINT1)
Serial.print ("OFF");
digitalWrite(HEATPIN1, LOW);
Serial.print ("ON ");
digitalWrite(HEATPIN1, HIGH);
printTemperature(Probe2);
if (ACTUAL2 < 100) {
Serial.print(" ");
Serial.print(SETPOINT2);
if (SETPOINT2 < 100) {
Serial.print(" ");
if (ACTUAL2 >= SETPOINT2)
Serial.print ("OFF.");
digitalWrite(HEATPIN2, LOW);
Serial.print ("ON .");
digitalWrite(HEATPIN2, HIGH);
Processing Code:
import controlP5.*;
ControlP5 cp5;
Knob myKnobA;
Knob myKnobB;
import processing.serial.*;
Serial port;
String ACTUAL1 = "";
String ACTUAL2 = "";
String SETPOINT1 = "";
String SETPOINT2 = "";
String HEATPIN1 = "";
String HEATPIN2 = "";
String data = "";
int index = 0;
PFont font;
smooth();
noStroke();
cp5 = new ControlP5(this);
myKnobA = cp5.addKnob("SETPOINT 1")
.setRange(50, 215)
.setValue(50)
.setPosition(50, 350)
.setRadius(50)
.setNumberOfTickMarks(33)
.setTickMarkLength(10)
.snapToTickMarks(true)
.setColorForeground(color(255))
.setColorBackground(color(0, 160, 100))
.setColorActive(color(255, 255, 0))
.setDragDirection(Knob.VERTICAL)
myKnobB = cp5.addKnob("SETPOINT 2")
.setRange(50, 215)
.setValue(50)
.setPosition(200, 350)
.setRadius(50)
size(360, 500);
port = new Serial(this, "COM4", 9600);
port.bufferUntil('.');
font = loadFont("AgencyFB-Bold-200.vlw");
textFont(font, 100);
void draw()
background(0, 0, 0);
fill(46, 209, 2);
text(ACTUAL1, 50, 100);
fill(0, 102, 153);
text(SETPOINT1, 50, 200);
fill(50, 2, 100);
text(HEATPIN1, 50, 300);
fill(46, 209, 2);
text(ACTUAL2, 200, 100);
fill(0, 102, 153);
text(SETPOINT2, 200, 200);
fill(50, 2, 100);
text(HEATPIN2, 200, 300);
float S1;
S1 = (myKnobA.getValue());
println(S1);
void keyPressed() {
switch(key) {
case('1'):
myKnobA.setValue(50);
case('2'):
myKnobA.setValue(215);
case('3'):
myKnobB.setValue(50);
case('4'):
myKnobB.setValue(215);
void serialEvent (Serial port)
data = port.readStringUntil('.');
data = data.substring(0, data.length() - 1);
index = data.indexOf(",");
ACTUAL1 = data.substring(0, data.length() - 16);
SETPOINT1 = data.substring(index+1, data.length() - 12);
HEATPIN1 = data.substring(index+4, data.length() - 9);
ACTUAL2 = data.substring(index+7, data.length() - 6);
SETPOINT2 = data.substring(index+10, data.length() - 3);
HEATPIN2 = data.substring(index+13, data.length());
