Hello I am from Serbia.Recently I started using Arduino and i wanted to make an project .My idea was to create a digital clock and print digits on LCD.I know how to print numbers on LCD but i don't know how to get time from PC.So if you have i time please answer.
Your Arduino can not read the time from the PC. So you will need an application on your PC that reads the time and sends that via e.g. Serial to the Arduino.
sterretje:
sterretje means to say that you will need to create an application on your PC to do this. sterretje does not expect you to do this, because there are easier ways...
Acting alone, Arduino does not make a good clock. It's crystal is not accurate enough, and when power is lost it will forget the time and must be adjusted again.
The are a few options to make a good clock with Arduino. These include GPS and NTP. But the easiest for a beginner is to get an RTC module. These have accurate crystals and a backup battery.
PaulRB:
So can you send me an example which i can use to load my RTC with current time.
