How do I know my serial.write is working?
Hi all, why is it when I use Realterm to see if my serial.write actually works, my command is different?
My command in sketch: FC 74 01 00 FE 71
Command shown on Realterm: E0 60 66 00 F8 06 FE
My code is just like that:
  Serial.begin(9600); // Replace with the appropriate baud rate
  // Additional setup code...
  // Write your command here
  Serial.write(0xFC);
  Serial.write(0x74);
  Serial.write(0x01);
  Serial.write(0x00);
  Serial.write(0xFE);
  Serial.write(0x71);
Serial.write() works as expected, so something else is wrong your setup. Post the details needed for forum members to diagnose the real problem.
Have you tinkered with the communication parameters 8N1?
Serial write is ‘sending’ binary, numeric values…
Most terminals are sending and receiving and displayimg ’ASCII’ text equivalents.
Your numeric output is showing ‘something else’, we need to understand your setup more, but the serial bit rate or framing is a good place to look.
It means that your connection between arduino and Realterm is not working
