Hi, i'm a beginner using the keyestudio 4wd bt robot car and i've been struggling to get a consistent and accurate 90 degree turn. I've adapted the kit's ultrasonic avoiding code to be suited for a maze but when I run the code the turns are inconsistent and make it impossible to complete the maze. I've currently been trying to figure out a perfect turn based off the location of the nearest corner, but I haven't been having much success. Any other recommended changes would also be greatly appreciated. Also sorry about the lack of comments, it was a bit too messy keeping the old ones from the original tutorial, so I'll try respond to any questions about clarification as soon as I can. I also would love to remove all the display code if possible, however i'm not sure which parts are which.
unsigned char front[] = {0x00,0x00,0x00,0x00,0x00,0x24,0x12,0x09,0x12,0x24,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char left[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x28,0x10,0x44,0x28,0x10,0x44,0x28,0x10,0x00};
unsigned char right[] = {0x00,0x10,0x28,0x44,0x10,0x28,0x44,0x10,0x28,0x44,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char STOP01[] = {0x2E,0x2A,0x3A,0x00,0x02,0x3E,0x02,0x00,0x3E,0x22,0x3E,0x00,0x3E,0x0A,0x0E,0x00};
unsigned char clear[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
#define SCL_Pin A5 //Set clock pin to A5
#define SDA_Pin A4 //Set data pin to A4
#define ML_Ctrl 4 //define direction control pin of B motor
#define ML_PWM 5 //define PWM control pin of B motor
#define MR_Ctrl 2 //define direction control pin of A motor
#define MR_PWM 9 //define PWM control pin of A motor
#include "SR04.h"//define the library of ultrasonic sensor
#define TRIG_PIN 12// set the signal input of ultrasonic sensor to D12
#define ECHO_PIN 13//set the signal output of ultrasonic sensor to D13
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long distance,a1,a2,diaMeasurement,no_counter,HAngle,hozMeasurement;//define three distance
const int servopin = 10;//set the pin of servo to D10
Serial.begin(9600);//open serial monitor and set baud rate to 9600
pinMode(ML_Ctrl, OUTPUT);//set direction control pin of B motor to OUTPUT
pinMode(ML_PWM, OUTPUT);//set PWM control pin of B motor to OUTPUT
pinMode(MR_Ctrl, OUTPUT);//set direction control pin of A motor to OUTPUT
pinMode(MR_PWM, OUTPUT);//set PWM control pin of A motor to OUTPUT
servopulse(servopin,90);// the angle of servo is 90 degree
delay(300);
pinMode(SCL_Pin,OUTPUT);// set clock pin to OUTPUT
pinMode(SDA_Pin,OUTPUT);//set data pin to OUTPUT
matrix_display(clear);// Clear the matrix display
avoid();//run the main program
void avoid()
distance=sr04.Distance(); //obtain the value detected by ultrasonic sensor
if((distance < 16)&&(distance > 0))//if the distance is greater than 0 and less than 20
car_Stop();//stop
matrix_display(STOP01); //show stop pattern
delay(100);
servopulse(servopin,185);//servo rotates to 185°
servopulse(servopin,180);//correction due to error with rotation for unknown reason
a1=sr04.Distance();//measure the distance
delay(100);
servopulse(servopin,0);//rotate to 0 degree
servopulse(servopin,0);//correction due to error with rotation for unknown reason
a2=sr04.Distance();//measure the distance
a1=round(a1 / 2);
a2=round(a2 / 2);
delay(100);
if (a1 = a2);
while (a1 = a2)
car_back();
delay(200);
car_Stop();//stop
delay(100);
delay(100);
a1=round(a1 / 2);
a2=round(a2 / 2);
car_back();
delay(150);
if(a1 > a2)//if distance a1 is greater than a2
servopulse(servopin,90);//rotate to 0 degree
HAngle = 90;
while (diaMeasurement < sr04.Distance()){
HAngle = HAngle - 2;
servopulse(servopin,HAngle);
diaMeasurement = sr04.Distance() - 1;
delay(1);
car_Stop();
delay(100);
while (hozMeasurement < sr04.Distance()){
car_left();//turn left
delay(1);
no_counter = no_counter + 1;
hozMeasurement = sr04.Distance() - 1;
servopulse(servopin,90);//servo rotates to 90 degree
servopulse(servopin,90);//correction due to error with rotation for unknown reason
delay(no_counter * 90 / HAngle - no_counter);
else//if the right distance is greater than the left
car_right();// turn right
matrix_display(front); //show forward pattern
delay(200);
else//otherwise
car_front();//go forward
matrix_display(front); // show forward pattern
void servopulse(int servopin,int myangle)//the running angle of servo
for(int i=0; i<30; i++)
int pulsewidth = (myangle*11)+500;
digitalWrite(servopin,HIGH);
delayMicroseconds(pulsewidth);
digitalWrite(servopin,LOW);
delay(20-pulsewidth/1000);
void car_front()//car goes forward
digitalWrite(ML_Ctrl,HIGH);//set direction control pin of B motor to HIGH level
analogWrite(ML_PWM,150);//set PWM control speed of B motor to 150
digitalWrite(MR_Ctrl,HIGH);//set direction control pin of A motor to HIGH level
analogWrite(MR_PWM,150);//set PWM control speed of A motor to 150
void car_back()//go back
digitalWrite(ML_Ctrl,LOW);//set direction control pin of B motor to LOW
analogWrite(ML_PWM,200);//set PWM control speed of B motor to 200
digitalWrite(MR_Ctrl,LOW);//set direction control pin of A motor to LOW
analogWrite(MR_PWM,200);//set PWM control speed of A motor to 200
void car_left()//car turns left
analogWrite(ML_PWM,225);//set PWM control speed of B motor to 200
analogWrite(MR_PWM,225);//set PWM control speed of A motor to 200
void car_right()//car turn rights
analogWrite(ML_PWM,210);//set PWM control speed of B motor to 200
analogWrite(MR_PWM,210);//set PWM control speed of A motor to 200
void car_Stop()//car stops
delay(50);
analogWrite(ML_PWM,0);//set PWM control speed of B motor to 0
analogWrite(MR_PWM,0);//set PWM control speed of A motor to 0
//this function is used for dot matrix display
void matrix_display(unsigned char matrix_value[])
IIC_start(); //the function to call the data transmission
IIC_send(0xc0); //Select address
for(int i = 0;i < 16;i++) //Pattern data has 16 bytes
IIC_send(matrix_value[i]); //data to convey patterns
IIC_end(); //end the transmission of patterns data
IIC_start();
IIC_send(0x8A); //display control, set pulse width to 4/16
IIC_end();
// the condition that data transmission starts
void IIC_start()
digitalWrite(SCL_Pin,HIGH);
delayMicroseconds(3);
digitalWrite(SDA_Pin,HIGH);
digitalWrite(SDA_Pin,LOW);
// transmit data
void IIC_send(unsigned char send_data)
for(char i = 0;i < 8;i++) //Every character has 8 bits
digitalWrite(SCL_Pin,LOW); //pull down the SCL_Pin to change the signal of SDA
if(send_data & 0x01) //1 or 0 of byte is used to set high and low level of SDA_Pin
digitalWrite(SCL_Pin,HIGH); //Pull up SCL_Pin to stop data transmission
send_data = send_data >> 1; //Detect bit by bit, so move the data right by one bit
//the sign that data transmission ends
void IIC_end()
