I am a massive noob and I did an LED lightshow for a school project. I was wondering if there was a way to make it more concise because the endless high, low, high, low gets boring after a while. I did not make the randomizer at the bottom, I collaborated with my teacher on that.
// Starter Code
pinMode(2, OUTPUT); //LED 1 is at pin 2
pinMode(3, OUTPUT); //LED 2 is at pin 3
pinMode(4, OUTPUT); //LED 1 is at pin 2
pinMode(5, OUTPUT); //LED 2 is at pin 3
pinMode(6, OUTPUT); //LED 1 is at pin 2
pinMode(7, OUTPUT); //LED 2 is at pin 3
pinMode(8, OUTPUT); //LED 1 is at pin 2
pinMode(9, OUTPUT); //LED 2 is at pin 3
pinMode(10, OUTPUT); //LED 1 is at pin 2
pinMode(11, OUTPUT); //LED 2 is at pin 3
//How you want the lights to flash goes here
{//start flash
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
delay(450);
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
delay(450);
delay(450);
delay(450);
//End Flash
//TRANSITION
//slow light up
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
//end slow light up
//seemingly random turn off
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(350);
//end random turn off
//TRANSITION
//start in from outside.
delay(200);
delay(200);
delay(200);
delay(200);
//end in from outside
//TRANSITION
delay(310);
//start end from outside
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
//TRANSITION
//start alternater
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
//end alternater
//TRANSITION
//start travelling light
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
//end traveling light
//TRANSITION
//start 2 at once
delay(450);
delay(450);
delay(450);
delay(450);
delay(450);
delay(450);
delay(450);
delay(450);
//end 2 at once
//TRANSITION
//start 3 at once
delay(450);
delay(450);
//end 3 at once
//start out from middle
delay(450);
delay(450);
delay(450);
delay(450);
delay(450);
delay(450);
//end out from middle
//TRANSITION
//start traveling light
delay(350);
delay(350);
delay(350);
delay(350);
delay(350);
delay(350);
delay(350);
delay(350);
delay(350);
delay(350);
//TRANSITION
//start randomizer
for(int i=0; i<10; i++){
int a = random(2,13);
int h = random(0,2);
digitalWrite(a, h);
delay(250);}
digitalWrite(a, h);
delay(250);}
digitalWrite(a, h);
delay(250);}
//end ramdomizer
//END LIGHTSHOW
