Please help
I'm trying to program an MG996R to rotate from 0 degrees to 90 degrees, stop for 5 seconds, rotate back to 0 degrees and end program. I have tried a few codes found on the internet but none give me my desired output. I am using an Arduino Uno to program my motor and my motor is being powered by an external source proving 5V at 2amps.
Any help will be appreciated thanks
Arduino Servo Test sketch
#include <Servo.h>
Servo servoMain; // Define our Servo
servoMain.attach(10); // servo on digital pin 10
servoMain.write(45); // Turn Servo Left to 45 degrees
delay(1000); // Wait 1 second
servoMain.write(0); // Turn Servo Left to 0 degrees
servoMain.write(90); // Turn Servo back to center position (90 degrees)
servoMain.write(135); // Turn Servo Right to 135 degrees
servoMain.write(180); // Turn Servo Right to 180 degrees
this code if off the internet and seems to work the best out of the other codes that I have tried
