Hello i am creating a library and would need to use interrupts in the class. usually what happens when i use an interrupt is i set it up in the void setup and just simply reference the function. but i do not know how to do it if its inside the class.
Here is a code of somewhat what i want (of course this throws an error)
class counter{
public:
void startCounting(){
attachInterrupt(digitalPinToInterrupt(4),this.addCount,CHANGE);
void stopCounting(){
detachInterrupt(digitalPinToInterrupt(4));
void addCount(){
count++;
private:
unsigned long count= 0;
i do not know how to write the ISR parameter
Will you instantiate multiple counter objects?
aarg:
yes but it will most likely use another pin for the interrupt
Then you have to have static enumeration of timers in your class.
aarg:
I apologize i dont quite follow what you mean by enum of timers, searching also did not yeild some relevant results
I have adjusted the code to accomodate settable pins to interrupt (if that matters)
class counter{
public:
counter(int pin){
Ipin=pin;
attachInterrupt(digitalPinToInterrupt(Ipin),this.addCount,CHANGE);
detachInterrupt(digitalPinToInterrupt(Ipin));
void addCount(){
count++;
private:
int Ipin;
As far as i know you cant place static on enums but there is a way around it
enum letters{a,b,c,d};
static letters x ;
but i could not see how i can apply it so that i can attach the ISR parameter to the function inside the class
Non-static class instance functions have a different signature than regular or static functions. Thus, their pointers are of an incompatible type to functions like attachInterrupt(). Here's a good reference: Standard C++
John41234:
Sorry about the terminology, I meant enumeration generally, not the C 'enum'. I mean that you will have to have a static record in your class, of which timers have been allocated by previous instantiations of the class. Static variables in a class, are shared between all instantiations.
Seems that its too difficult for me to understand. Do you think you can give me an example using my sample code?
