How do you make an arduino communicate with another arduino?
I already succeeded in making the sender send hello to the receiver arduino. But now I want to make a code where I press a button on the sender arduino and it then sends a signal to the receiver arduino to light up an LED lamp.
For this project I'm using arduino UNO for both.
With these codes.
Code of sender arduino:
char mystr[5] = "Hello"; //String data
  // Begin the Serial at 9600 Baud
  Serial.write(mystr,5); //Write the serial data
Code of receiver arduino:
char mystr[10]; //Initialized variable to store recieved data
  Serial.readBytes(mystr,5); //Read the serial data and store in var
  Serial.println(mystr); //Print data on Serial Monitor
So first try changing the sender code so that it only sends hello when you push a buton.
1. You add the following codes at the appropriate place of the Sender Sketch:
pinMode(2, INPUT_PULLUP);   //connect a Switch across DPin-2 and GND
while(digitalRead(2) != LOW)
   ;//wait until Swicth is pressed
Serial.write(mystr, 5);
2. You add the following codes at the appropriate place of the Receiver Sketch:
#define LED 2
pinMode(LED, OUTPUT);
byte n = Serial.available();
if(n != 0)
   Serial.readBytes(mystr, 5);
   mystr[5] ='\0';
   if(strcmp(mystr, "Hello") == 0)
       digitalWrite(LED, HIGH);   //LED is turned On
Fix this problem first
The string actually has 6 characters in it including the trailing '\0' that the compiler will add to mark the end of the string. By declaring teh array as having 5 elements it means that the '\0' is written to memory that does not belong to the array
char mystr[] = "Hello"; //String data
would be better as it allows the compiler to work out teh size of the array
should only read when there's something to receive
look this over
const byte PinLed = LED_BUILTIN;
enum { LedOff = LOW, LedOn = HIGH };
void loop ()
    if (Serial.available ())  {
        char buf [80];
        int n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        // toggle led on/off
        digitalWrite (PinLed, ! digitalRead (PinLed));
void setup ()
    Serial.begin (9600);
    pinMode      (PinLed, OUTPUT);
    digitalWrite (PinLed, LedOn);
  • not sure what you will see on serial monitor if serial pins are connected between Arduinos
  • need to recognize command to turn LED on or off
