How do you save SD card read() values?
Hello,
I am working on a project that requires me to retrieve saved data from an SD card and saving that data into a variable (most likely a character array or String). I need some guidance on how to achieve this.
Here is a sample of my code
Any help is appreciated
  myFile = SD.open(profile, FILE_READ);
  while(myFile.available()){
   Serial.write(myFile.read()); // I dont want to write to monitor I want to save these characters
Why are you using Serial.write ?
I used it to illustrate exactly what I don't want to do. I don't want to write to the serial monitor, I want to save what I read instead.
I think you need to understand how to use myFile.read( ) function .
What does it do?
Do you know?
To my understanding, it returns the next character in the array
Not an array, but I think it's called a stream, and as such you can use any of the techniques from the Stream class which means Serial.
So for example in the sketch below, parseFloat() (clue's in the name :wink: ) parses some floats out of an SD card stream. (Not actually advocating the use of parsefloat() since it blocks afaik, but you get the idea.)
  BASED ON SD card file dump
  This example shows how to read a file from the SD card using the
  SD library and send it over the serial port.
  The circuit:
   SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
  created  22 December 2010
  by Limor Fried
  modified 9 Apr 2012
  by Tom Igoe
  This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4;
float myVar1;
float myVar2;
float myVar3;
float myVar4;
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  Serial.println("card initialized.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("floats.txt"); //<<<<<<<<<<<<<<<<<<<<<< set file name here
  // if the file is available, read from it:
  if (dataFile)
    while (dataFile.available())
      //parse the next 4 values out of the file:
      myVar1 = dataFile.parseFloat();
      myVar2 = dataFile.parseFloat();
      myVar3 = dataFile.parseFloat();
      myVar4 = dataFile.parseFloat();
      //print them to the monitor:
      Serial.println(myVar1);
      Serial.println(myVar2);
      Serial.println(myVar3);
      Serial.println(myVar4);
      //go back to the top for the next line...
    }//while data available
    //or ....
    Serial.println(".... no more data");
    dataFile.close();
  }// if datafile
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening the data file");
}//setup
As far as I know you can use any Serial technique to read an SD card; Robin2's serial tutorial might help.
