How do you retain variable values in the Opta.
I'd like them to still be there after it re-powers up.
I've found the 'Parameters (Non volatile)' under Configuration->Opta->Public objects->Parameters and have added a list of variables, but they aren't stored and reset to zero when powered back on!
If anyone has any information on this, I'd be grateful for some info.
You want to store some values inside of the memory of the PLC.
Your PLC works in collaboration with an arduino opta.
So what is the real question?
Do you mean:
How can my Opta-C++-Code send values to my PLC so the PLC will store these values
in the PLC- internal-non-volatile-memory?
Or do you mean:
You adjusted some values inside the PLC and now these values shall read out by the arduino-opta and then be stored
in the flash-memory of the Arduino-Opta ?
You are working on an informatic project. (even if a PLC is part of it) and what is most needed in an informatic project is - guess what ? sufficient precise information
So the PLC will store these values in the PLC- internal-non-volatile -memory ???
This is the question I'm having difficulty in doing.
I've worked out how to get variables to and from the Arduino sketch to the PLC by using the PLCIn.### & PLCOut.###. So I've got the first part of your question, thank you.
The part I cannot get to work is the second half of your question. Getting the PLC-internal-non-volatile memory to work!
Would you have any advise on how to setup and use the non-volatile memory within the PLC.
best regards
Mark
Is your system build from an Arduino Opta and
some second NON-ARDUINO-device which must communicate with each other ?
or
is your system only the Arduino-Opta?
And in case there are two parts
NON-Arduino-PLC
Arduino-Opta programmed by the Arduino PLC-IDE
What type of NON-Arduino-PLC is this?
My understanding of your question is:
How can I store data in the NON-Arduino-PLC?
Is this correct?
Maybe it would be good if you add a picture that shows all important parts of your system.
this are
each and evey powersupply (yes they are important!)
The system I have is the following:
1x Mean Well Switch Mode Power Supply 24vdc @ 1.7A
1x Arduino-Opta Plc
4x Potentiometers to simulate analog inputs on 4x Plc inputs.
2x Switches on 2x Plc inputs.
4x Led's on the 4x Plc outputs.
1x RS485 device connected to RS485 port on Plc.
All of my prototype system as above is all working fine.
Quick question...how did you build your variables and are they all directly tied to sensors? I am trying to scale a device using a function block but I need the output to be a variable I can use elsewhere in my code. Ive had a hard time building my program because I dont want to build in a sketch. I think several people on these forums are familiar with the arduino sketches. Im trying to use the opta as a true plc.
Thanks for posting the update, I've been having the same issue.
The RETAIN attribute provides a solution, but requires a lot of boilerplate code to copy the values to and from the varaibles in 'Parameters'. In my project the 'Parameters' varaibles get read/written via TCP Modbus from an external UI. So on startup I would have to copy the values out of the RETAINed vars, then when they change I would have to copy them back - quite a bit of code and it could easily be overlooked if something changed.
An obvious feature would be making it possible to set the RETAIN attribute on the 'Parameters'.
Did you find any way to easily tie the global RETAINed varaibles to the 'Parameters' varaibles?
