How does this enum declaration work ?
I recently came across this code which usesd enums,and switch cases. I saw this declaration for the enum:
enum : byte {IDLE, MIDDLE, END} start = IDLE;
What is the purpose of the "byte" part and also the part after the the curly parenthesis "start = IDLE".
Also why does the enum have no name.
Is there any documentation explaining this as I cannot find any similar structures for this enum
fxokdo:
What is the purpose of the "byte" part...
By default int sized storage (2 or 4 bytes) is used. The byte part reduces that.
fxokdo:
...and also the part after the the curly parenthesis "start = IDLE".
Declare a variable named start then assign that variable an initial value.
fxokdo:
Not needed. C++ supports anonymous types.
fxokdo:
In my experience, Microsoft provides fairly good C++ documentation.
fxokdo:
[..] the part after the the curly parenthesis "start = IDLE".
I think this code should be read as:
 enum : byte {IDLE, MIDDLE, END};
 start = IDLE;
fxokdo:
https://playground.arduino.cc/Code/Enum/
Erik_Baas:
start = IDLE;
Nope, that won't work. You can't declare 'start' without giving it a type and you can't use an anonymous type because it has no name. One option:
 enum EnumName : byte {IDLE, MIDDLE, END};
EnumName start = IDLE;
This might also work. 'automatic' means "Use the type of the initializer.":
automatic start = IDLE;
Erik_Baas:
start = END;
Nope: compiler says "'automatic' was not declared in this scope".
Sorry, I got the keyword wrong. It should have been 'auto', not 'automatic'. It's a relatively new feature so I have used it very little.
