How fast or How to Send Data To Arduino?
Dear all,
As shown in the attached picture. I have a c# winform app to extract dedected pattern.
I am able to extract the pattern, list the coordinates of the white pixel and converting pixel coordinates to the Gcode (upper textbox).
To send Gcodes to my CNC, i have uploaded the Bresenham based arduino code (the given link: GcodeCNCDemo2Axis.ino - Wokwi ESP32, STM32, Arduino Simulator) to my cnc shield mounted arduino.
My problem is whenever i click the send data button shown in picture, i am sending the coordinates to the arduino but motors stops just after a few movements.
I thought that data size is to much and there is not enough time for arduino to go every point then i added a timer which send data every 3s. But the same thing happens again.
What is wrong?
Is there something wrong with arduino code or there is something related with C# code?
I think i need to do something with arduino code because if i deactivate the serialport.Write, i see every Gcode in the textbox every 3s.
Any help i appreciate.
Please provide code here, in code tags. Not all of us mess with the simulators.
// 2 Axis CNC Demo
// dan@marginallycelver.com 2013-08-30
// Copyright at end of file.
// please see http://www.github.com/MarginallyClever/GcodeCNCDemo for more information.
// Modified for Wokwi at https://wokwi.com/projects/327748577668366932
// copied from https://github.com/MarginallyClever/GcodeCNCDemo/blob/master/GcodeCNCDemo2Axis/GcodeCNCDemo2Axis.ino
// with modifications to parseNumber, serialBuffer, drivers
// David Forrest 2022-04-01
#include "config.h"
// GLOBALS
char  buffer[MAX_BUF];  // where we store the message until we get a newline
int   sofar;            // how much is in the buffer
float px, py;      // location
// speeds
float fr =     0;  // human version
long  step_delay;  // machine version
// settings
char mode_abs=1;   // absolute mode?
// METHODS
 * delay for the appropriate number of microseconds
 * @input ms how many milliseconds to wait
void pause(long ms) {
  delay(ms/1000);
  delayMicroseconds(ms%1000);  // delayMicroseconds doesn't work for values > ~16k.
 * Set the feedrate (speed motors will move)
 * @input nfr the new speed in steps/second
void feedrate(float nfr) {
  if(fr==nfr) return;  // same as last time?  quit now.
  if(nfr>MAX_FEEDRATE || nfr<MIN_FEEDRATE) {  // don't allow crazy feed rates
    Serial.print(F("New feedrate must be greater than "));
    Serial.print(MIN_FEEDRATE);
    Serial.print(F("steps/s and less than "));
    Serial.print(MAX_FEEDRATE);
    Serial.println(F("steps/s."));
    return;
  step_delay = 1000000.0/nfr;
  fr = nfr;
 * Set the logical position
 * @input npx new position x
 * @input npy new position y
void position(float npx,float npy) {
  // here is a good place to add sanity tests
  px=npx;
  py=npy;
 * Uses bresenham's line algorithm to move both motors
 * @input newx the destination x position
 * @input newy the destination y position
void line(float newx,float newy) {
  long i;
  long over= 0;
  long dx  = newx-px;
  long dy  = newy-py;
  int dirx = dx>0?1:-1;
  int diry = dy>0?-1:1;  // because the motors are mounted in opposite directions
  dx = abs(dx);
  dy = abs(dy);
  if(dx>dy) {
    over = dx/2;
    for(i=0; i<dx; ++i) {
      m1step(dirx);
      over += dy;
      if(over>=dx) {
        over -= dx;
        m2step(diry);
      pause(step_delay);
    over = dy/2;
    for(i=0; i<dy; ++i) {
      m2step(diry);
      over += dx;
      if(over >= dy) {
        over -= dy;
        m1step(dirx);
      pause(step_delay);
  px = newx;
  py = newy;
// returns angle of dy/dx as a value from 0...2PI
float atan3(float dy,float dx) {
  float a = atan2(dy,dx);
  if(a<0) a = (PI*2.0)+a;
  return a;
// This method assumes the limits have already been checked.
// This method assumes the start and end radius match.
// This method assumes arcs are not >180 degrees (PI radians)
// cx/cy - center of circle
// x/y - end position
// dir - ARC_CW or ARC_CCW to control direction of arc
void arc(float cx,float cy,float x,float y,float dir) {
  // get radius
  float dx = px - cx;
  float dy = py - cy;
  float radius=sqrt(dx*dx+dy*dy);
  // find angle of arc (sweep)
  float angle1=atan3(dy,dx);
  float angle2=atan3(y-cy,x-cx);
  float theta=angle2-angle1;
  if(dir>0 && theta<0) angle2+=2*PI;
  else if(dir<0 && theta>0) angle1+=2*PI;
  // get length of arc
  // float circ=PI*2.0*radius;
  // float len=theta*circ/(PI*2.0);
  // simplifies to
  float len = abs(theta) * radius;
  int i, segments = ceil( len * MM_PER_SEGMENT );
  float nx, ny, angle3, scale;
  for(i=0;i<segments;++i) {
    // interpolate around the arc
    scale = ((float)i)/((float)segments);
    angle3 = ( theta * scale ) + angle1;
    nx = cx + cos(angle3) * radius;
    ny = cy + sin(angle3) * radius;
    // send it to the planner
    line(nx,ny);
  line(x,y);
 * Look for character /code/ in the buffer and read the float that immediately follows it.
 * @return the value found.  If nothing is found, /val/ is returned.
 * @input code the character to look for.
 * @input val the return value if /code/ is not found.
float parsenumber(char code,float val) {
  char *ptr=buffer;  // start at the beginning of buffer
  while((long)ptr > 1 && (*ptr) && (long)ptr < (long)buffer+sofar) {  // walk to the end
    if(*ptr==code) {  // if you find code on your walk,
      return atof(ptr+1);  // convert the digits that follow into a float and return it
    ptr=strchr(ptr,' ')+1;  // take a step from here to the letter after the next space
  return val;  // end reached, nothing found, return default val.
 * write a string followed by a float to the serial line.  Convenient for debugging.
 * @input code the string.
 * @input val the float.
void output(const char *code,float val) {
  Serial.print(code);
  Serial.println(val);
 * print the current position, feedrate, and absolute mode.
void where() {
  output("X",px);
  output("Y",py);
  output("F",fr);
  Serial.println(mode_abs?"ABS":"REL");
 * display helpful information
void help() {
  Serial.print(F("GcodeCNCDemo2AxisV1 "));
  Serial.println(VERSION);
  Serial.println(F("Commands:"));
  Serial.println(F("G00 [X(steps)] [Y(steps)] [F(feedrate)]; - line"));
  Serial.println(F("G01 [X(steps)] [Y(steps)] [F(feedrate)]; - line"));
  Serial.println(F("G02 [X(steps)] [Y(steps)] [I(steps)] [J(steps)] [F(feedrate)]; - clockwise arc"));
  Serial.println(F("G03 [X(steps)] [Y(steps)] [I(steps)] [J(steps)] [F(feedrate)]; - counter-clockwise arc"));
  Serial.println(F("G04 P[seconds]; - delay"));
  Serial.println(F("G90; - absolute mode"));
  Serial.println(F("G91; - relative mode"));
  Serial.println(F("G92 [X(steps)] [Y(steps)]; - change logical position"));
  Serial.println(F("M18; - disable motors"));
  Serial.println(F("M100; - this help message"));
  Serial.println(F("M114; - report position and feedrate"));
  Serial.println(F("All commands must end with a newline."));
 * Read the input buffer and find any recognized commands.  One G or M command per line.
void processCommand() {
  int cmd = parsenumber('G',-1);
  switch(cmd) {
  case  0:
  case  1: { // line
    feedrate(parsenumber('F',fr));
    line( parsenumber('X',(mode_abs?px:0)) + (mode_abs?0:px),
          parsenumber('Y',(mode_abs?py:0)) + (mode_abs?0:py) );
  case 2:
  case 3: {  // arc
      arc(parsenumber('I',(mode_abs?px:0)) + (mode_abs?0:px),
          parsenumber('J',(mode_abs?py:0)) + (mode_abs?0:py),
          parsenumber('Y',(mode_abs?py:0)) + (mode_abs?0:py),
          (cmd==2) ? -1 : 1);
  case  4:  pause(parsenumber('P',0)*1000);  break;  // dwell
  case 90:  mode_abs=1;  break;  // absolute mode
  case 91:  mode_abs=0;  break;  // relative mode
  case 92:  // set logical position
    position( parsenumber('X',0),
              parsenumber('Y',0) );
  default:  break;
  cmd = parsenumber('M',-1);
  switch(cmd) {
  case 18:  // disable motors
    disable();
  case 100:  help();  break;
  case 114:  where();  break;
  default:  break;
 * prepares the input buffer to receive a new message and tells the serial connected device it is ready for more.
void ready() {
  sofar=0;  // clear input buffer
  Serial.print(F(">"));  // signal ready to receive input
 * First thing this machine does on startup.  Runs only once.
  Serial.begin(BAUD);  // open coms
  setup_controller();
  position(0,0);  // set staring position
  feedrate((MAX_FEEDRATE + MIN_FEEDRATE)/2);  // set default speed
  help();  // say hello
  ready();
 * After setup() this machine will repeat loop() forever.
  // listen for serial commands
  while(Serial.available() > 0) {  // if something is available
    char c=Serial.read();  // get it
    Serial.print(c);  // repeat it back so I know you got the message
    if(sofar<MAX_BUF-1) buffer[sofar++]=c;  // store it
    if((c=='\n') || (c == '\r')) {
      // entire message received
      buffer[sofar]=0;  // end the buffer so string functions work right
      Serial.print(F("\r\n"));  // echo a return character for humans
      processCommand();  // do something with the command
      ready();
* This file is part of GcodeCNCDemo.
* GcodeCNCDemo is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* GcodeCNCDemo is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Foobar. If not, see <http://www.gnu.org/licenses/>.
// 2 Axis CNC Demo
// modified by lsahidin@yahoo.com added HG7881 stepper controller
// Warning.
// * to reduce and avoid overheat on HG7881, use M18 after every G00, G01, G02, G03 on Gcode * \\
#if CONTROLLER == PASS_STEP
// INCLUDES
#include <Stepper.h> // // https://github.com/arduino-libraries/Stepper/blob/master/src/Stepper.h
// GLOBALS
// Initialize Stepper.h stepper controller
// Stepper.h motor(Step, pinA_IA, pinA_IB, pinB_IA, pin_B_IB);
Stepper m1((int)STEPS_PER_TURN, 6,7,8,9);
Stepper m2((int)STEPS_PER_TURN, 5,4,3,2);
// METHODS
void m1step(int dir) {
m1.step(dir);
void m2step(int dir) {
m2.step(dir);
void disable() {
//m1.release();
//m2.release();
void setup_controller() {
m1.setSpeed(100);
m2.setSpeed(100);
#endif // CONTROLLER == HG7881
// 2 Axis CNC Demo
// dan@marginallycelver.com 2015-12-23
#if CONTROLLER == RAMPS
// INCLUDES
// CONSTANTS
#define M1_STEP 54
#define M1_DIR 55
#define M1_ENA 38
#define M2_STEP 60
#define M2_DIR 61
#define M2_ENA 56
// limit switches
#define SWITCH1 3
#define SWITCH2 14
// GLOBALS
// METHODS
digitalWrite(M1_ENA,HIGH);
digitalWrite(M1_DIR,dir);
digitalWrite(M1_STEP,HIGH);
digitalWrite(M1_STEP,LOW);
digitalWrite(M2_ENA,HIGH);
digitalWrite(M2_DIR,dir);
digitalWrite(M2_STEP,HIGH);
digitalWrite(M2_STEP,LOW);
void disable() {
digitalWrite(M1_ENA,LOW);
digitalWrite(M2_ENA,LOW);
pinMode(M1_ENA,OUTPUT);
pinMode(M2_ENA,OUTPUT);
pinMode(M1_STEP,OUTPUT);
pinMode(M2_STEP,OUTPUT);
pinMode(M1_DIR,OUTPUT);
pinMode(M2_DIR,OUTPUT);
#endif // CONTROLLER == RAMPS
#ifndef CONFIG_H
#define CONFIG_H
// 2 Axis CNC Demo
// CONSTANTS
// supported control boards
#define AMS1 (1)
#define AMS2 (2)
#define HG7881 (3) // HG7881 Stepper Driver
#define PASS_STEP (4) // pass-through Stepper.h
// change this line to select a different control board for your CNC.
#define CONTROLLER PASS_STEP
#define VERSION        (1)  // firmware version
#define BAUD           (9600)  // How fast is the Arduino talking?
#define MAX_BUF        (64)  // What is the longest message Arduino can store?
#define STEPS_PER_TURN (200)  // depends on your stepper motor.  most are 200.
#define MIN_STEP_DELAY (50.0)
#define MAX_FEEDRATE   (1000000.0/MIN_STEP_DELAY)
#define MIN_FEEDRATE   (0.01)
// for arc directions
#define ARC_CW          (1)
#define ARC_CCW         (-1)
// Arcs are split into many line segments.  How long are the segments?
#define MM_PER_SEGMENT  (10)
// METHODS
extern void m1step(int dir);
extern void m2step(int dir);
extern void disable();
extern void setup_controller();
#endif
  "version": 1,
  "author": "David Forrest",
  "editor": "wokwi",
  "parts": [
    { "type": "wokwi-arduino-uno", "id": "uno", "top": 231.47, "left": -76.16, "attrs": {} },
      "type": "wokwi-stepper-motor",
      "id": "stepper1",
      "top": -105.13,
      "left": 153.3,
      "attrs": { "display": "steps", "arrow": "brown", "gearRatio": "1:1"}
      "id": "stepper2",
      "top": -103.64,
      "left": -99.08,
      "attrs": { "display": "steps", "arrow": "black", "gearRatio": "1:1"}
  "connections": [
    [ "stepper1:B-", "uno:2", "green", [ "v57.38", "h-115.51" ] ],
    [ "stepper1:B+", "uno:3", "green", [ "v48.08", "h-49.05" ] ],
    [ "stepper1:A+", "uno:4", "green", [ "v36.79", "h-94.51" ] ],
    [ "stepper1:A-", "uno:5", "green", [ "v29.48", "h-34.7" ] ],
    [ "stepper2:B-", "uno:6", "green", [ "v22.68", "h65.8" ] ],
    [ "stepper2:B+", "uno:7", "green", [ "v31.31", "h65.18" ] ],
    [ "stepper2:A+", "uno:8", "green", [ "v41.28", "h62.89" ] ],
    [ "stepper2:A-", "uno:9", "green", [ "v50.58", "h71.56" ] ]
Okay. So you're pumping data to the Arduino at 9600 baud. How fast are you sending the data? I suspect way too much data for the Arduino to process, and the buffer overflows and data is lost. Increasing the baud rate won't help, because it's up to the Arduino to keep up with the incoming data.
Do you have any suggestion?
Update: I searched a bir and got some idea.
It is suggested to make an array of all data before sending to Arduino Uno.
Do you have any experience about it? Does it help? @camsysca
I asked, how fast are you sending the data? IIRC, you have a PC program doing the sending, so I have no ability to test that.
I wrote the code given below to find out sending time. It shows zero means too fast.
                DateTime startTime = DateTime.Now;
                DateTime endTime = DateTime.Now;
                TimeSpan elapsedTime = endTime - startTime;
                double seconds = elapsedTime.TotalSeconds;
                textBox4.Text = Convert.ToString(seconds);
What can i do? @camsysca
I addition i have updated the arduino code for the baudrate from 57600 to 250000 and byte amount to the 512 from 64.
Not sure what you think that code does. Not even sure what language it's in. Looks to me like you make two consecutive calls to get the time, wouldn't surprise me that the difference is zero, or very nearly so.
If you're simply sending as fast as you can, then your Arduino must be coded to empty the buffer at that maximum character rate. What I was hoping you'd try to determine is how frequently your code sends blocks of data.
Something like
start:
Get timestamp
save it
display delta since last timestamp
Create data
Send data
goto start
could you fix post #3 and add the code tags where they belong?
I fixed the code and the source of the code is already written in post #1.
the arduino collects the incoming data and does nothing until it receives the \r or \n denoting the end of a command
So no there is no win in aggregating the data before sending it.
may be you could slightly modify the protocol to also include a start marker so that the arduino would know it's not jumping and recording something in the middle of a command (ie lost bytes)
