How learn Samsung Air Conditioner IR codes (Raw)?
Hello,
I´m triyng to learn IR codes from Samsung Air conditioner remote control.
I´ve found many sites teaching how proceed to do this but no success.
Yesterday finally found something diferent in this website:
The IR code captured was very long but is not formatted to send by IRremote library.
Someone could help to format it? If I remove the hyfens and remove the first value is enough to make this code works?
18 - Auto - Fan High
Raw: (349) 704, -18644, 2984, -8912, 544, -484, 508, -1476, 512, -488, 508, -484, 508, -508, 552, -440, 484, -512, 484, -508, 488, -508, 484, -1504, 512, -480, 512, -484, 512, -1476, 512, -480, 512, -480, 516, -1476, 508, -1480, 508, -1476, 512, -1504, 484, -1504, 552, -440, 484, -508, 488, -508, 484, -508, 512, -484, 512, -480, 512, -484, 512, -480, 512, -484, 512, -484, 508, -484, 512, -484, 508, -484, 512, -480, 512, -512, 480, -512, 484, -508, 484, -508, 548, -448, 484, -512, 484, -508, 484, -508, 580, -416, 512, -480, 512, -484, 512, -480, 512, -480, 516, -480, 512, -484, 508, -484, 512, -484, 580, -412, 512, -1480, 508, -1500, 484, -1504, 552, -1436, 512, -2956, 3008, -8940, 512, -1476, 512, -484, 512, -480, 512, -484, 508, -484, 512, -484, 508, -488, 508, -480, 512, -512, 484, -1500, 484, -516, 480, -512, 480, -1504, 484, -508, 488, -1500, 512, -1476, 512, -1476, 512, -1476, 512, -1476, 512, -1476, 512, -484, 508, -512, 484, -508, 484, -508, 484, -512, 484, -508, 484, -512, 484, -508, 484, -512, 508, -488, 508, -484, 508, -484, 512, -480, 512, -484, 512, -480, 512, -484, 512, -484, 508, -512, 484, -484, 508, -488, 504, -488, 508, -508, 484, -512, 484, -508, 484, -512, 484, -508, 484, -508, 512, -484, 512, -480, 512, -484, 512, -484, 508, -484, 512, -480, 512, -484, 508, -484, 512, -484, 508, -2980, 2984, -8944, 512, -1500, 484, -512, 484, -508, 484, -512, 484, -508, 484, -508, 488, -508, 512, -484, 508, -484, 512, -1476, 512, -480, 512, -484, 508, -1480, 508, -1480, 508, -1480, 508, -1504, 484, -508, 484, -1504, 484, -1508, 480, -1504, 512, -1476, 512, -1472, 516, -1472, 512, -1480, 508, -1480, 508, -484, 512, -484, 508, -512, 484, -1500, 484, -1504, 484, -1504, 484, -512, 508, -484, 512, -484, 508, -484, 512, -480, 512, -484, 512, -1476, 512, -484, 508, -484, 508, -1480, 508, -488, 508, -508, 484, -512, 480, -512, 484, -512, 484, -508, 484, -512, 484, -508, 512, -480, 512, -484, 508, -484, 512, -1476, 512, -1476, 512, -1476, 512, -1476, 508
Just use the sendRaw function of the IRremote IRLib library. Because one of your signals is longer than 16383 uSecs - IRremote will not work.
You should follow the documentation and examples provided with the IRlib Library.
