Dear sir, i will make a coding of fuzzy logic with arduino UNO, this coding for aeroponic system,i have two input variabel, there are temperature and humidity, and the output is Duration of pump. So, the rules is 15 rules. Please help me for making a coding for arduino. Thx sir ![]()
this is a rules of fuzzy:
If (Humidity is Lembab) and (Temperatur is Dingin) then (Duration is C)
If (Humidity is Lembab) and (Temperatur is Sedang) then (Duration is S)
3.If (Humidity is Lembab) and (Temperatur is Hangat) then (Duration is AS)
4.If (Humidity is AgakLembab) and (Temperatur is Dingin) then (Duration is
S)
5. If (Humidity is AgakLembab) and (Temperatur is Sedang) then (Duration is
AS)
6. If (Humidity is AgakLembab) and (Temperatur is Hangat) then (Duration is
SD)
7. If (Humidity is Normal) and (Temperatur is Dingin) then (Duration is AS)
If (Humidity is Normal) and (Temperatur is Sedang) then (Duration is SD)
If (Humidity is Normal) and (Temperatur is Hangat) then (Duration is AL)
If (Humidity is AgakKering) and (Temperatur is Dingin) then (Duration
is SD)
11. If (Humidity is AgakKering) and (Temperatur is Sedang) then (Duration
is AL)
12. If (Humidity is AgakKering) and (Temperatur is Hangat) then (Duration
is LY)
13. If (Humidity is Kering) and (Temperatur is Dingin) then (Duration is
AL)
14. If (Humidity is Kering) and (Temperatur is Sedang) then (Duration is
LY)
15. If (Humidity is Kering) and (Temperatur is Hangat) then (Duration is L)
Are the input variables actual numeric values to be translated into those words or are they already received as those words?
Do you plan on receiving them as words through, say a serial port, or numbers?
Or do you just want to know the logic behind setting Duration?
Verry fuzzy!
How about a proportional control? More temperature = more duration.
I have no idea what the non-english words mean, but if they are the names of variables I don't see anything fuzzy in Reply #1. It should convert directly into Arduino IF statements.
On the other hand if the words represent actions (e.g. rising or turning) you will need to provide a translation.
...R
Google Translate recognizes the words as Indonesian:
Dingin = cold
Sedang = moderate
Hangat = warm
Lembab = damp
Agak Lembab = somewhat damp
Agak Kering = somewhat dry
Kering = dry
johnwasser:
Those words don't seem to be fuzzy. Each one could be assigned a number.
...R
Oops. I forgot NORMAL humidity. That gives you three levels of temperature and five levels of dampness. You can use a two-dimensional array to pick the proper 'Duration' once you classify the two inputs.
| Lembab damp |
AgakLembab somewhat damp |
Normal | AgakKering somewhat dry |
Kering dry |
| Dingin cold |
C | S | AS | SD | AL |
| Sedang moderate |
S | AS | SD | AL | LY |
| Hangat warm |
AS | SD | AL | LY | L |
Thank you all for help me...
i was make a rules, and i was make a coding for arduino.. but there are some problem and error again. There are "expected initialized before "." token."
here a picture and here the coding... please help me sir why error like that
thx
//Â FILE:Â dht11_test1.pde
// PURPOSE: DHT11 library test sketch for Arduino
#include <dht11.h>
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
dht11 DHT;
#define DHT11_PIN 6
long val = 0;
void spraytime(int,int);
void fuzzy(void);
boolean DHT.temperature;
boolean DHT.humidity;
int relaypompa = 9;Â Â Â Â Â Â Â // pin 9 Arduino dihubungkan dengan pin SIGNAL modul Relay
int relaykipas = 10;Â Â Â Â Â Â Â // pin 10 Arduino dihubungkan dengan pin SIGNAL modul Relay
 Serial.println("DHT TEST PROGRAM ");
 Serial.print("LIBRARY VERSION: ");
 Serial.println(DHT11LIB_VERSION);
 Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
Â
 lcd.begin(16, 2);
 /*Serial.begin(115200); // Open serial connection to report values to host
 Serial.println("Starting up");*/
 //set the cursor to column 0, line 1
 // (note: line 1 is the second row, since counting begins with 0):
 lcd.setCursor(0, 1);
 lcd.print("Starting up...");
 delay(2000);
 lcd.clear();
Â
 pinMode(relaypompa, OUTPUT);    // pin 9 sebagai output
 pinMode(relaykipas, OUTPUT);    // pin 10 sebagai output
 int chk;
 Serial.print("DHT11, \t");
 chk = DHT.read(DHT11_PIN);  // READ DATA
 switch (chk)
  case DHTLIB_OK:Â
        Serial.print("OK,\t");
  case DHTLIB_ERROR_CHECKSUM:
        Serial.print("Checksum error,\t");
  case DHTLIB_ERROR_TIMEOUT:
        Serial.print("Time out error,\t");
  default:
        Serial.print("Unknown error,\t");
//print to lcd
 lcd.print("Temp:   C");
 lcd.setCursor(7, 1);
 lcd.print(DHT.temperature,2);
 lcd.setCursor(0, 0);
 lcd.print("Humid:   %");
 lcd.setCursor(7, 0);
 lcd.print(DHT.humidity,2);
Â
 delay(2000);
   val = digitalRead(DHT.temperature);  // read the value from the sensor
   val = digitalRead(DHT.humidity);  // read the value from the sensor
 Â
  void spraytime(int count,int del)
   digitalWrite(relaypompa, LOW);
   digitalWrite(relaykipas, LOW);
   delay(del);
   digitalWrite(relaypompa, HIGH);
   digitalWrite(relaykipas, HIGH);
   delay(del);
 void fuzzy(void)
  if (DHT.temperature>=25&&DHT.temperature<=27)
   { // Jika suhunya lebih dari atau sama dengan 30 derajat
     if(DHT.humidity>=70%%DHT.humidity<=73)
     spraytime(1,420000);
     else if(DHT.humidity>=71&&DHT.humidity<=75)
     spraytime(1,360000);
     else if(DHT.humidity>=73&&DHT.humidity<=77)
     spraytime(1,300000);
     else if(DHT.humidity>=75&&DHT.humidity<=79)
     spraytime(1,180000);
     else if(DHT.humidity>=77&&DHT.humidity<=80)
     spraytime(1,120000);
  else if(DHT.temperature>=26&&DHT.temperature<=29)
     spraytime(1,540000);
  else if(DHT.temperature>=28&&DHT.temperature<=30)
     spraytime(1,600000);
  delay(2000);
Robin2:
Those words don't seem to be fuzzy. Each one could be assigned a number....R
yes, every membership function have range of number, there are my reply posting above.. thx sir ![]()
johnwasser:
Lembab
dampAgakLembab
somewhat dampNormal AgakKering
somewhat dryKering
dryDingin
coldC S AS SD AL Sedang
moderateS AS SD AL LY Hangat
warmAS SD AL LY L
Yes sir, my result rules like that, thx ![]()
help me for my reply post above, there are some problem again sir, why like that? ![]()
Rd_Vergiansyah:
My guess would be that the DHT11 library is not installed properly or is not being used properly. Did the library come with any example sketches? They would be in the menu File->Examples->dht11->
johnwasser:
i have the library from this forum, about dht11 sensor with fuzzy logic on arduino, i copy and paste the code to my IDE and the result is like that. Yes the library with any examples sketches sir.
Rd_Vergiansyah:
Sorry, but I don't see that. Which reply are you referring to?
...R
