This all started with buying the current limited 4 amp variable power supply which can be powered by a single 18650 battery. I 3D printed the LEXI3 breadboard from the Cults3D website and also printed a base plate for them. This is because the ESP32 is broad and only leaves a single hole to play with either side of the processor with the conventional breadboard. With the LEXI3, I now have 4 holes per pin of the ESP32. They are all glued together and is now a fully powered ESP32 breadboard assembly.
I then wanted to test it, so I added an ESP32 WROOM and an ESP32-C3 and connected them so I could send and receive data between each other using UART (TX/RX). This worked great, so I added a Micro SD card module and started to write the received data to the to the Micro SD card.
I then thought it would be a good idea to build on this to create a data logger, so I had to add the code to access an NTP Server to get the current date and time for the log entries. This was working great and really happy with the result.
Here’s a sample of what’s logged. It’s only sample data but as stated above, it works quite well
While researching, 3D printing and building this, the 2x 433Mhz radio modules arrived which I bought from AliExpress to have a play with. I’ve created loads of successful projects using the ESP32s WiFi and Bluetooth so I wanted to try something different like radio. This meant adding another ESP32 which I didn’t have space for, so I had to print another LEXI3 breadboard with the the spinal joiners and linked them together. Even though the C3 has limited pins, it is capable of attaching the radio transmitter, the Micro SD card and a couple of LEDs.
The second ESP32 WROOM would be the receiver. I had major problems getting the radio side of the project working because I accidentally ordered 2x 433MHz transmitters and 2x 315MHz receivers by mistake. I was so annoyed with myself because they would never talk to each other. I then ordered the corresponding receivers and transmitters, so I now have 4x sets of each. Viewing the received data in the Serial Monitor wasn’t good enough, so I added a TFT screen to display the received data. I’ve also changed the text colour of different commands.
Now, looking at the project, I have basically created a simple Serial Monitor which I didn’t start out to create. This then gave me an idea. Why not take what I’ve learned and transform this ‘rats nest’ into a UART Serial Monitor & Data Logger using a CYD (Cheap Yellow Display). I wouldn’t need the radio modules, but everything else could be done with a single CYD.
Each project I create now, which I 3D print the casings for, will have a UART output port for the CYD UART Serial Monitor & Data Logger. I’ve just ordered another CYD to create this ![]()
It’s amazing how simple tinkering can lead to an actual working and useful project. To say I’m obsessed with the ESP32 processor is an absolute understatement. I’ll add a link soon to a video I made of it, which I’ll put on YouTube.
Thanks for reading
Alex
