How "separate" data with xbee ?
Hi, I use xbee for send data by sensor to arduino with ethernet shield (for website). But I have a problem, i receive the data on "char" but i have 3 variables and they are assemble. For example I have 3 data : 3, 15, 511. data receiving 315511, how i separate ?
Sorry for my very bad english
thank you
how i separate ?
The fact that the data was transmitted and received by a pair of XBees has no bearing on the problem.
The problem is that you failed to post any code, so we can't see if you have a string to parse, a String to parse, or not a hope in hell of parsing anything.
Having a string is best.
You need to figure out how each character set is different from the next. Do you have control over how the data is sent?
Can you send the data with separators - such as "3,15,511" ? That will make the parsing very much easier - especially if the length of the parts can change.
There is a parse example in Serial Input Basics
...R
I post a pic of my problem, left is the transmitter and right is receiver. I send 3 data but at the reception the are all in on variable (choseLue), how i separate ??? :confused:
Image from Reply #4 so we don't have to download it. See Image Guide
...R
Apart from the fact that your image is too small to read it would have been much more useful (and polite) if you had responded to the Replies you have already received.
DON'T post photos of text.
See How to use the Forum
...R
What is the point of determining how much serial data there is to read, if you then read a character regardless of whether there is anything to read?
I can't see how you expect to parse any data when you don't save the data in a way that permits parsing.
