OK I have tried every freaking thing I can think of I do not understand where I am supposed to put the codes... I am at a complete loss and do not know what to do. I do not care what pin the button signal is sent to all i want is to be able to switch between the two codes with a switch.
code1
int potpin = 2; // POT connected to digital pin 2 - pos/neg are left and right connections on POT
int rpin = 9; // Red
int gpin = 10; // Green
int bpin = 11; // Blue
float h; // Hue range
int h_int; // Hue color
int r = 0, g = 0, b = 0; // Default RGB values
int val = 0; // Set POT value to default 0
void h2rgb(float h, int& R, int& G, int& B); // Instantiate h2rgb and it's variables a.k.a Hue to RGB
void setup() // Run once, when the sketch starts
Serial.begin(9600); // Begin the output of data to serial
void loop() // Run over and over again
val = analogRead(potpin); // Read the pin and display the value
h = ((float)val)/1024; // Get the range. pot value / 1024
h_int = (int) 360*h; // Get the color hue by multiplying by 360
h2rgb(h,r,g,b); // Call the h2rgb function passing it the hue value
Serial.print("POT value: ");
Serial.print(val); // Pot value
Serial.print(" = Hue of ");
Serial.print(h_int); // Color Hue value
Serial.print(" degrees. RGB values: ");
Serial.print(r); // Red value
Serial.print(" ");
Serial.print(g); // Green value
Serial.print(" ");
Serial.println(b); // Blue value
analogWrite(rpin, r); // Changes red led
analogWrite(gpin, g); // Changes green led
analogWrite(bpin, b); // Changes blue led
void h2rgb(float h, int& R, int& G, int& B) {
// Used HSV --> RGB function
// HSV - Hue, Saturation, Value
// RGB - Red, Green, Blue - example (255,255,255)
// Function below does a bunch of math to convert HSV values to RGB
int var_i;
float S=1, V=1, var_1, var_2, var_3, var_h, var_r, var_g, var_b;
if ( S == 0 ) //HSV values = 0 ÷ 1
R = V * 255;
G = V * 255;
B = V * 255;
var_h = h * 6;
if ( var_h == 6 ) var_h = 0; //H must be < 1
var_i = int( var_h ) ; //Or ... var_i = floor( var_h )
var_1 = V * ( 1 - S );
var_2 = V * ( 1 - S * ( var_h - var_i ) );
var_3 = V * ( 1 - S * ( 1 - ( var_h - var_i ) ) );
if ( var_i == 0 ) {
var_r = V ;
var_g = var_3 ;
var_b = var_1 ;
else if ( var_i == 1 ) {
var_r = var_2 ;
var_g = V ;
var_b = var_1 ;
else if ( var_i == 2 ) {
var_r = var_1 ;
var_g = V ;
var_b = var_3 ;
else if ( var_i == 3 ) {
var_r = var_1 ;
var_g = var_2 ;
var_b = V ;
else if ( var_i == 4 ) {
var_r = var_3 ;
var_g = var_1 ;
var_b = V ;
else {
var_r = V ;
var_g = var_1 ;
var_b = var_2 ;
R = (1-var_r) * 255; //RGB results = 0 ÷ 255
G = (1-var_g) * 255;
B = (1-var_b) * 255;
code2
Author: Seth Leeper
Version: 1
Purpose: To cycle the tri-color LED
contained within the Sparkfun starter kit
through every available color combination with
a fade in/fade out effect.
int RED = 9; // RED pin of the LED to PWM pin 9
int GREEN = 10; // GREEN pin of the LED to PWM pin 10
int BLUE = 11; // BLUE pin of the LED to PWM pin 11
int DELAY_TIME = 50; //changes speed of fading
int MAX_BRIGHT = 255; //sets maximum brightness, 255 max brightness
int COLOR_MIX = 0; //variable to change the colors that are mixed in switch statement
void fade_in(int x) //loop that gradually turns the LED on using PWM
int counter;
for(counter = 0; counter < x; counter++)
led_mixer(COLOR_MIX, counter);
delay(DELAY_TIME);
void fade_out(int x) //loop that gradually turns the LED off using PWM
int counter;
for(counter = x; counter > 0; counter--)
delay(DELAY_TIME);
void led_mixer(int color, int x) //uses switch statement to mix color combinations
switch(color)
case 0:
analogWrite(RED, x);
case 1:
analogWrite(GREEN, x);
case 2:
analogWrite(BLUE, x);
case 3:
case 4:
case 5:
default:
// nothing for setup
void loop() //loop forever
fade_in(MAX_BRIGHT); //gradually turn the LED on to max brightness
fade_out(MAX_BRIGHT); //gradually turn off the LED
COLOR_MIX++; //increment to the next color combination
if(COLOR_MIX == 7) //if all color combinations have been displayed, reset the cycle
COLOR_MIX = 0;
