How to activate a debug function defined in a library from an arduino sketch?
This is probably a stupid question, but I couldn’t find a solution.
I would like to activate / deactivate a debug function of a library (basically print some information on the serial interface) from an adruino sketch.
So in the library (let’s say LIB.h) I have defined:
#ifndef LIB_h
#define LIB_h
#ifndef DEBUG
#define DEBUG 0
#endif
if (DEBUG) Serial.println (“hello”);
#endif
Now in my sketch I would like to turn the debug mode on staring my sketch with:
#define DEBUG 1
#include <LIB.h>
But this doesn’t work (defining DEBUG 1 or 0 is not recognised by the library).
How can I solve this problem?
Thanks in advance
Robert
Make it a variable, not a #define.
Amend the library to use this variable. (You can use extern to pass variables from one module to another).
Easy :slight_smile:
Thanks for the tip
Ronert
