How to add arrow keys, enter, Escape keys to project
I have a keyboard emulator which also uses a combination of momentary switches and rotary encoders all works fine. But I cannot figure out how to add the following keys: keyboard arrow keys, Escape key and Enter key. When I try to change the char keys in the first section, say I remove '5' or 'g' and want up arrow nothing happens.
Is there anyone that can help with this code
#include <Keypad.h>
#include <Keyboard.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 5
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
char keys[NUMROWS][NUMCOLS] = {
  {'5','2','v','4','5'},
  {'6','7','8','9','0'},
  {'p','b','u','p','e'},
  {'t','g','c','q','j'},
  {'f','a','m','s','o'},
struct rotarykeysdef {
  byte pin1;
  byte pin2;
  char ccwchar;
  char cwchar;
  volatile unsigned char state;
rotarykeysdef rotarykeys[NUMROTARIES] {
  {0,1,'i','d',0},
  {2,3,'r','n',0},
  {4,5,'h','l',0},
  {6,7,'3','1',0},
  {8,9,'x','z',0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10};
Keypad buttbx = Keypad( makeKeymap(keys), rowPins, colPins, NUMROWS, NUMCOLS);
  rotary_init();
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
    if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                              Keyboard.press(buttbx.key[i].kchar);
                    case HOLD:
                    case RELEASED:
                              Keyboard.release(buttbx.key[i].kchar);
                    case IDLE:
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotarykeys[i].pin1, INPUT);
    pinMode(rotarykeys[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotarykeys[i].pin1, HIGH);
      digitalWrite(rotarykeys[i].pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotarykeys[_i].pin2) << 1) | digitalRead(rotarykeys[_i].pin1);
  rotarykeys[_i].state = ttable[rotarykeys[_i].state & 0xf][pinstate];
  return (rotarykeys[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Keyboard.press(rotarykeys[i].ccwchar); delay(50); Keyboard.release(rotarykeys[i].ccwchar);
    if (result == DIR_CW) {
      Keyboard.press(rotarykeys[i].cwchar); delay(50); Keyboard.release(rotarykeys[i].cwchar);
Is your question "What is the ascii character for arrow keys, enter, escape?" Maybe :
Thanks for the reply. My question is how I can get those key to work in this code, when I type the ASCII characters or codes to use them nothing happens, its like they are not recognised by the library in this code.I was wondering if there was away to activate them in the code
While there are ASCII characters for Escape (0x1b) and Enter (0x0d or 0c0a) isn't an ASCII character for the arrow keys.
Do you mean you want a particular button to cause the script to send a specific keyboard keycode? Maybe you need these:
Keyboard Modifiers and Special Keys - Arduino Reference
What did you try for the arrow, enter and escape keys?
The codes for the Return/Enter key, Escape key and the arrow keys are defined in Keyboard.h:
#define KEY_RETURN      0xB0
#define KEY_ESC       0xB1
#define KEY_UP_ARROW    0xDA
#define KEY_DOWN_ARROW    0xD9
#define KEY_LEFT_ARROW    0xD8
#define KEY_RIGHT_ARROW   0xD7
