I would like to teach my Arduino IDE to use my AVR Dragon's HVPP (High Voltage Parallel Programming) interface to upload compiled sketches to my boards (an ATMega1284P-PU in this case, supported by mighty1284p
Working setup so far:
Arduino IDE with mighty1284p
, I added this to the boards.txt of mighty1284p
to support my uC's internal-RC-oscillator clockrates of 1MHz and 8MHz.
avrdude
can talk to the m1284p
and set the fuses:
avrdude -c dragon_pp -P usb -p m1284p -U lfuse:w:0x62:m -U hfuse:w:0x99:m -U efuse:w:0xFF:m -U lock:w:0xFF:m
I can compile / check a sketch successfully, then upload the temporarily created .hex
manually to the 1284 using the Dragon:
cd /var/folders/px/xmf1dygn6p5_fn1hh05c6gyr0000gn/T/build4082512148637729777.tmp/
avrdude -p m1284p -c dragon_pp -P usb -U flash:w:Fade.cpp.hex
This works but includes the manual step of cd
ing into the temporary build directory and manually uplading the .hex
How would I use the AVR Dragon's HVPP directly from within the Arduino IDE? I have added a section to programmers.txt
as such:
dragonpp.name=AVR Dragon HVPP
dragonpp.communication=usb
dragonpp.protocol=dragon_pp
dragonpp.force=false
which I assumed would be correct for the above avrdude
parameters.
Within the IDE I choose Tools - Programmer - AVR Dragon HVPP
, then Upload
. The debug output shows this:
(...correct compiling, linking and such...)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega1284p -carduino -P/dev/tty.Bluetooth-PDA-Sync -b115200 -D -Uflash:w:/var/folders/px/xmf1dygn6p5_fn1hh05c6gyr0000gn/T/build1852336263469118058.tmp/Fade.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/cts/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.Bluetooth-PDA-Sync
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude done. Thank you.
So the -p
parameter is correct, but -c
and -P
are wrong.
Any ideas how I could add the Dragon correctly?
