This should fail because 'filename' is not defined. If you had used the expression "myFileName.c_str()" it should fail because "myFileName" is a character array, not a "String".
#include <SPI.h> // Include the SPI library for Ethernet and SD card communication
#include <SD.h> // Include the SD library for accessing files on the SD card
#include <Ethernet.h> // Include the Ethernet library for Internet connectivity
#include <Wire.h> // Include the Wire library for I2C communication
#include <LiquidCrystal_I2C.h> // Include the LiquidCrystal_I2C library for controlling the LCD display
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // Set up the MAC address of the Arduino using a byte array
EthernetClient client; // Create an instance of the EthernetClient class to handle Internet connectivity
File myFile; // Declare a File object for accessing files on the SD card
LiquidCrystal_I2C lcd(0x27, 20, 4); // Create an instance of the LiquidCrystal_I2C class for controlling the LCD display
int myDelay = 3000; // Set a delay of 3 seconds
char myFileName[] = "Results.txt"; // Set the filename for the results file that will be created on the SD card
lcd.init(); // Initialize the LCD display
lcd.backlight(); // Turn on the backlight of the LCD display
lcd.setCursor(0, 0); // Set the cursor position to the first row, first column
lcd.print("VERSION 1 "); // Display a message on the LCD display
lcd.setCursor(0, 1); // Set the cursor position to the second row, first column
lcd.print(" NETWORK SCANNER "); // Display a message on the LCD display
delay(myDelay); // Wait for a specified period of time
lcd.clear(); // Clear the LCD display
lcd.print("Initializing Network"); // Display a message on the LCD display
Ethernet.begin(mac); // Initialize the Ethernet library with the specified MAC address
delay(myDelay); // Wait for the Ethernet shield to initialize
lcd.print(" Network Ready "); // Display a message on the LCD display
lcd.print(" IP: "); // Display a message on the LCD display
lcd.print(Ethernet.localIP()); // Display the local IP address on the LCD display
lcd.print("Initializing SD card"); // Display a message on the LCD display
if (!SD.begin(4)) { // If the SD card fails to initialize
lcd.println("init failed! "); // Display an error message on the LCD display
while (1) // Infinite loop to halt program execution
lcd.print(" SD Card Ready "); // Display a message on the LCD display
lcd.print(myFileName); // Display the filename for the results file on the LCD display
myFile = SD.open(myFileName, FILE_WRITE); // Open a file on the SD card for writing and store the file object in "myFile"
if (myFile) { // If the file was opened successfully, execute the following code block
myFile.println(Ethernet.localIP()); // Write the local IP address to the file
pingScan(); // Call the "pingScan" function
myFile.close(); // Close the file
lcd.clear(); // Clear the LCD screen
lcd.setCursor(0, 0); // Set the cursor to the top left corner of the LCD screen
lcd.print("VERSION 1 "); // Display the message on the first line of the LCD screen
lcd.setCursor(0, 1); // Set the cursor to the beginning of the second line of the LCD screen
lcd.print(" NETWORK SCANNER "); // Display the message " NETWORK SCANNER" on the second line of the LCD screen
lcd.setCursor(0, 2); // Set the cursor to the beginning of the third line of the LCD screen
lcd.print(" Scan Complete "); // Display the message " Scan Complete" on the third line of the LCD screen
delay(myDelay); // Delay for "myDelay" milliseconds
lcd.setCursor(0, 3); // Set the cursor to the beginning of the fourth line of the LCD screen
lcd.print("Results saved to SD "); // Display the message "Results saved to SD" on the fourth line of the LCD screen
} else { // If the file failed to open, execute the following code block
lcd.println("Error Opening SD "); // Display the message "Error Opening SD" on the fourth line of the LCD screen
myFile = SD.open(myFileName); // re-open the file for reading:
if (myFile) { //
while (myFile.available()) { // read from the file until there's nothing else in it:
Serial.write(myFile.read()); //
myFile.close(); // close the file:
} else { //
Serial.print("Error Closing SD "); // if the file didn't close, print an error:
// Future options here
void pingScan() {
lcd.print("Scanning network... "); // Display the message "Scanning network..." on the first line of the LCD screen
for (int i = 1; i <= 12; i++) { // Loop through a subset of IP addresses for testing purposes. Using 12 instead of 254 for time testing
// Create an IPAddress object with the current IP address
IPAddress address(Ethernet.localIP()[0], Ethernet.localIP()[1], Ethernet.localIP()[2], i);
if (client.connect(address, 80)) { // If the client is able to connect to the IP address on port 80
client.stop(); // Stop the client connection
lcd.print("IP Addresses Found "); // Display the message "IP Addresses Found" on the third line of the LCD screen
lcd.print(" "); // Clear the fourth line of the LCD screen
lcd.print(Ethernet.localIP()[0]); // Display the first part of the local IP address on the fourth line of the LCD screen
lcd.print("."); // Display a period on the fourth line of the LCD screen
lcd.print(Ethernet.localIP()[1]); // Display the second part of the local IP address on the fourth line of the LCD screen
lcd.print(Ethernet.localIP()[2]); // Display the third part of the local IP address on the fourth line of the LCD screen
lcd.print(i); // Display the current IP address being scanned on the fourth line of the LCD screen
myFile.print(Ethernet.localIP()[0]); // Write the first part of the local IP address to the SD card file
myFile.print("."); // Write a period to the SD card file
myFile.print(Ethernet.localIP()[1]); // Write the second part of the local IP address to the SD card file
myFile.print(Ethernet.localIP()[2]); // Write the third part of the local IP address to the SD card file
myFile.println(i); // Write the current IP address being scanned to the SD card file
The error is not from IDE, it is from the code "Error Opening SD "
On the Uno, you could be running out of memory, with unpredictable results. Post the link message that describes the memory usage statistics. Keep in mind that the SD library uses 1/4 of SRAM for the file buffer, when opening a file.
To save SRAM memory, all the string constants in print() statements should be put into flash memory using the F macro, e.g. replace this:
with this:
lcd.print(F("Initializing Network")); // Display a message on the LCD display
Sketch uses 25744 bytes (79%) of program storage space. Maximum is 32256 bytes.
Global variables use 1742 bytes (85%) of dynamic memory, leaving 306 bytes for local variables. Maximum is 2048 bytes.
Sketch uses 25846 bytes (80%) of program storage space. Maximum is 32256 bytes.
Global variables use 1452 bytes (70%) of dynamic memory, leaving 596 bytes for local variables. Maximum is 2048 bytes.
