How to assign many values to an array without loop
Hi.
I want to asign an global array some values see code at the asciito14segment():
int ch11[] = {0,0,0,0,0,0,1};
int ch12[] = {0,0,0,0,1,0,0};
void setup(){
void loop(){}
void asciito14segment(){
    ch11[] = {1,0,1,0,0,1,1};
    ch12 = {0,0,0,1,0,1,1};
for the first I get that error:
In function 'void asciito14segment(char, int)':
error: expected primary-expression before ']' token
and for the second:
error: expected primary-expression before '{' toke
Is something like that possible without a loop? Maybe with pointers?
Something like:
      int chtmp[] =  {1,0,1,0,0,1,1};
      *ch11 = &chtmp[];
it didnt work I tryed it. How would it work?
thanks
Yoiu could use "memcpy" and a constant array.
Hi.
thanks for memcpy.
      byte ch12tmp[] = {1,0,0,0,0,0,0};
      memcpy(ch11, ch11tmp, 7);
thats working
but where something like that
      memcpy(ch11, {1,0,0,0,0,0,0}, 7);
possible?
but where something like that possible?
No.
if your values consist of 8 ones and zeros then you can store them in bytes (or use ints for 16 bits).
for example:
byte ch[] = {
             B00000001,
             B00000100
void setup(){
void loop(){}
    ch[0] = B1010011;
    ch[1] = B0001011;
use bitRead to get the value of a bit: http://arduino.cc/en/Reference/BitRead
isBitSet = bitRead(ch[number], position); // returns true if the bit in the current position is set
You might look at what they did to define PSTR in <avr/pgmspace.h>
Something similar MIGHT be possible with a list of integers instead of a string. (It's pretty cryptic stuff, and I couldn't figure out a way to get a list of numbers with embedded commas but no surrounding parens. I think it would work with a separate macro for each length of string:
memcpy(ch11, LSTR7(1,0,0,0,0,0,0), 7);
memcpy(ch11, LSTR3(1,0,0), 3);
Where are strcpy() and memcpy() documented?
I'm having some problems (like variable assignment) with the language, but haven't found a good reference.
Thanks for any suggestions.
They're more-or-less "standard" C library functions, documented along with avr-libc: avr-libc: AVR Libc
