Hi. The following website explains how to make a 12V NiMH battery float charger.
https://www.eeweb.com/blog/extreme_circuits/float-charger-for-nimh-cells
Below I will post in order
- My circuit (which works)
- The float charger circuit (12V version - 10 cells)
- My proposed circuit which will charge the batteries whenever the DC plug is attached.
I'm 97% certain that something will be wrong/inadequate, so I am looking for ways to make it work.
I have a feeling that the charger circuit does not do balance charging, due to the lack of mosfets.
The added circuitry needs priority over the charging circuit, but I feel like having the charger and circuit in parallel, they are both going to just draw the current they both need.
Note: my circuit draws 47uA when only the PIR is active and up to 200mA when the Arduino is on (the mosfet turns it on).
I would go ahead and try it if my stuff was not in storage right now.
See "proposed circuit.png".
Thanks!
