How to build a reconfigurable firmware ?
I need to build a "reconfigurable" firmware, but don't know where to start. Some details :
This is a joystick firmware, but I want the user to be able to reconfigure buttons and leds behaviour (at first) using an external app (or web page). I know about the MMjoy2 firmware, but the source is nowhere to be found. I really don't know how the software is able to reconfigure the firmware "on the fly" :
  • does the software updates the arduino using variables in eeprom ?
  • does the software rebuilds / recompiles the firmware each time the configuration changes ?
  • Something else ?
How would you achieve that ?
I really don't know where to start with this project, although I have quite some experience with arduino.
Thank you
Welcome to the forum
Saving the user preferences to EEPROM sounds like the way to go
If you use an Arduino board with WiFi and/or Bluetooth capabilities then the software could be configured using a Web page or an app running on a 'phone
Thanks for your answer.
I know how to do it (sort of) using an ESP8266 or ESP32 using a webpage, unfortunately, this arduino won't have any WiFi or Bluetooth capability. It will be a atmega32u4 custom board.
The MMjoy2 software could do it using USB. It seems it writes to the eeprom. This is how it works :
  • first, put the arduino in bootloader mode
  • upload the MMjoy2 firmware from the MMjoy GUI
  • set the buttons / axis configuration inside the MMjoy GUI
  • save the configuration to the arduino inside the MMjoy GUI (then a popup window explicitly says "writing to eeprom")
I could find examples about reading/writing to the eeprom inside an arduino sketch, but I could not find any guides about how to do it "externaly".
Nothing stops you from writing a serial protocol to write EEPROM locations which in turn configure the program. For example use location zero for the pin number of a button. Pull that number in setup, use that pin as the button pin.
