i want to build a sun tracking system.
I want to do this with four LDRs (photoresistors) as light sensor (2 for x-axis and 2 for y-axis) and two servo motors (1 for x-axis and 1 for y-axis).
I`ve bought four LDRs an unfortunatelly all four give me other results (resistance) wenn I test them with the same light source.
Do You have any idea how can I calibrate these sensors? Is it possible?
I've tested two LDRs. One of them I've calibrated with potentiometer, so both LDRs gave me the same resistance.
When I've changed the light intensity, the resistance was different again.
Having a sensor interrupting the processor doesn't strikes me as very efficient. :\ Although, the difference in price from the LDR to this one is quite noticeable. :\ I guess it depends on how much time you want to spend calibrating it...
I think one way is having a light bulb and use a potmeter in series with the LDR to adjust the reading at the same level of light in the room. Ok... maybe two bulbs. LOL
