How to catch a index value outside array range?
Let's say there is an array[5] = {4, 5, 3, 6, 7}. What is the real value associated with array[8] since it is outside the domain of index? I want my code to stop looping the main code when it reaches the max limit of its index. Any advice on how to do that?
#define NUM_ENTRIES(ARRAY)      (sizeof(ARRAY) / sizeof(ARRAY[0]))
    const int       array[] = { 4, 5, 3, 6, 7 };
    const size_t    len     = NUM_ENTRIES(array);
    static size_t   index   = 0;
    if ( index < len )
        Serial.println(array[index++]);
    // ... WHATEVER ELSE YOU WISH TO DO ...
EDIT: Or perhaps you meant something more like ...
    while ( index >= len )
sizeof() does a nice job:
for (int i = 0; i < sizeof(myArray)/sizeof(myArray[0]); i++)
You can also get fancy when using functions and use templates
// T is what type it is: byte, char, int...unsigned long \
   N is the number of indexes in the array
template<typename T, size_t N>
void FooBar(T (&arr)[N] )
   // was type byte changed to size_t suggested by lloyddean
    for (size_t idx = 0; i < N; i++)
      Serial.println(arr[ i ]);
Not that it makes any difference for his described usage, but, given that 'N' is of type 'size_t' you should probably also have the loop local iterator variable 'idx' be of type 'size_t'.
   for ( size_t idx = 0; i < N; i++ )
lloyddean:
I think the compiler would just type convert idx to unsigned if it's needed.
Strictly speaking, you point out something that should be habitual!
shamilsaeed:
Whatever happens to be 4 bytes after the end of that array in memory. C does no bounds checking!
It may or may not remain constant as your program runs, depending on whether that specific memory location is used for something else.
Where is a '0' at last place. Text strings?
These aren't zero-terminated arrays.
A c string is a null (0) terminated char array - but that is only the case with arrays. The 0 is used to signify that the end of the string has been reached - if you forget that null, when you try to pass it to a function looking for a string, it will keep reading until it gets to a 0, which will likely involve reading things after the start of the array.
